Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: High spark and knock after COS3 install
    Gav,
    Full flash (and two step) no longer required, just make the amendments and then cal flash in the changes. Until you get happy/confidence do the cal flash then trundle along gently to check the log before venturing into aggressive throttle/high map areas.
    Jim
    2000 LS1 M6, No EGR/Air/PS/CATs. TR230 Cam, COS3, OLSD, LC1 Wideband fitted, Procharger P1SC, 2 Bar MAP, Siemans Dekka 60Lb Injectors.
    All wrapped up in a 2000Lb AC Cobra Replica
    Anything below 40kPa will be ok, yes 15kPa is stock.
    +1 what Jim said, do cal flash from now on.
  1. Spark ETC Table pulling spark Temp reading too high
    By s10mods in forum Gen III V8 Specific
    Last Post: September 8th, 2015, 08:26 AM
  2. Spark High Octane table
    By SHOGOR in forum Gen III V8 Specific
    Last Post: July 19th, 2008, 01:53 AM
  3. Help my spark advance is too high
    By Big Block in forum Custom Operating Systems
    Last Post: April 25th, 2008, 03:48 PM
  4. Knock after COS #3 install, but never had knock before
    By CRU SS N in forum Custom Operating Systems
    Last Post: June 15th, 2007, 09:07 PM
  5. High/Low Spark Map
    By purrvert in forum General (Petrol, Gas, Ethanol)
    Last Post: August 12th, 2006, 07:27 PM
