Results 1 to 2 of 2
Thread: Bidirectional controls and spark....
    Default Bidirectional controls and spark....
    How much real time control do you have with the birectional controls? I haven't used this feature yet and wanted to know if we load the car on the dyno, can we add timing under load. Also if we are adding timing, how can we see what load vs. rpm cell we are in so we can go back and make the permanent change.
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Oct 2004
    I have found that using the bidi control for spark at idle have caused the car to surge, not sure about under load conditions.
    Anyway, later versions (get the latest) of EFILive will highlight the cell in the Tune Tool when scanning/recording, no longer just at playback/review of the log So you can probably use that to identify the cell you wish to change.
    The better answer IMO is to get the RoadRunner. That way you can actually increase/decrease the actual spark value without having to override the PCM control.
    Andrew
    EFILive Crew
  1. Replies: 8
    Last Post: May 16th, 2007, 10:04 AM
  2. Pull timing with bidirectional controls to test for KR?
    By Xtnct00WS6 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 27th, 2006, 04:11 PM
  3. Bidirectional Controls and V7
    By bink in forum General (Petrol, Gas, Ethanol)
    Last Post: October 8th, 2005, 04:53 PM
