Results 1 to 7 of 7
Thread: Help to make Calc PIDs in V8
    May 2010
    Default Help to make Calc PIDs in V8
    Hello EFI Live team
    I hope there will be a tutorial to help make Calculated PIDs in V8
    Thanks in advance
    EFILive Tuner
    I thought the was a thread which briefly showed how, but I can't find it I'll look for it.
    In the meantime see attached example file from my folder C:\Users\joecar\Documents\EFILive\V8\Config (remove the .txt from the end of the filename).
    Code:
    [Groups]
    GLOBAL=Global Functions
    WO2SER=Wide Band O2 Sensors (Serial-Comms)
    WO2CAN=Wide Band O2 Sensors (CAN-bus)
    [GLOBAL]
    FUNCTION="Global Functions",factor,0
    [GLOBAL.FUNCTION]
    0=|-- GLOBAL.FUNCTION
    1=|function iff(x,y,z)
    2=|if (x) then return y else return z end
    3=|end
    [WO2SER]
    WO2BEN="Base Efficiency Numerator (Serial-Comms)(Dynamically-Leanest)",factor,3
    [WO2SER.WO2BEN]
    0=|-- WO2SER.WO2BEN
    1=|return iff(pid("WO2LAM1")>pid("WO2LAM2"),pid("WO2LAM1"),pid("WO2LAM2"))*pid("EQIVRATIO")
    [WO2CAN]
    WO2BEN="Base Efficiency Numerator (CAN-bus)(Dynamically-Leanest)",factor,3
    [WO2CAN.WO2BEN]
    0=|-- WO2CAN.WO2BEN
    1=|return iff(pid("WO2S11")>pid("WO2S21"),pid("WO2S11"),pid("WO2S21"))/pid("EQ_RAT")
    Sep 2009
    Sorry for my ignorance Joe. I just looked at the thread again and realized there was an attachment!
    Thank-you!
    Why not just use the built in Calc PIDs editor?
    In the Scan Window, click the drop down arrow on the [Options] button and select "Calculated PIDs" (or just use the Ctrl+K hot key).
    Calc PIDs in data logs are updated instantly (when you close the calc pids editor, or click [Apply]) , no need to try and understand/edit the calc pid *.ini data files.
    You can also export/import calculated PID groups to easily share your own calc PIDs with other users. Just right click on the group's icon and select import or export.
    Paul, you meant the down arrow on the [Config] button.
    Yes, I'm getting too old for this...
  1. Replies: 1
    Last Post: January 29th, 2015, 10:14 AM
  2. CALC.PIDs
    By COONDOG96 in forum Tips and tricks
    Last Post: January 25th, 2014, 02:03 PM
  3. Can someone help me out with calc.pids
    By pavetim in forum Gen III V8 Specific
    Last Post: January 24th, 2011, 04:30 AM
  4. Calc Pids
    By minytrker in forum External A/D inputs
    Last Post: February 19th, 2010, 04:39 AM
  5. CALC pids
    By purrvert in forum General
    Last Post: October 24th, 2005, 11:32 PM
