Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Help to make Calc PIDs in V8
    Quote Originally Posted by Gelf VXR
    Hi Joe, if i am following correctly, create a group name (up to me), create a pid name (up to me), copy and paste code in its entirety, save job done?
    Yes, pretty much, as long as the syntax of the pasted code is correct...
    when editing the pid equation in V8, there is a button fx Test to check that the pid is correctly syntaxed.
    That button is also available if you double click on a pid in the green pane.
    Feb 2007
    Hi Joe, downloaded and moved your UserCalculatedpids.ini file to the said location, I dont see the calc pids show up up in the right hand pane nor the pid editor, i took some screen shots
Name:	Screenshot 2018-03-09 04.38.53.png
ID:	21898   Click image for larger version.
Name:	Screenshot 2018-03-09 04.36.48.png
ID:	21899   Click image for larger version.
Name:	Screenshot 2018-03-09 04.37.10.png
ID:	21900   Click image for larger version.
Name:	Screenshot 2018-03-09 04.39.01.png
ID:	21901   Click image for larger version.
Name:	Screenshot 2018-03-09 04.41.09.png
Name:	Screenshot 2018-03-09 04.41.13.png
ID:	21903   Click image for larger version.
Name:	Screenshot 2018-03-09 04.42.00.png
    Feb 2007
    I fixed it, after i copied the file to the location, another is automatically created, with cog icon, but the file is empty, i copied and paste the test into the editor, and deleted the original file i copied
Name:	Screenshot 2018-03-09 05.01.27.png
ID:	21907   Click image for larger version.
Name:	Screenshot 2018-03-09 05.01.19.png
    Feb 2007
    Glad to see calc pids available in V8
    Cool, good job
  1. Replies: 1
    Last Post: January 29th, 2015, 11:14 AM
  2. CALC.PIDs
    By COONDOG96 in forum Tips and tricks
    Last Post: January 25th, 2014, 03:03 PM
  3. Can someone help me out with calc.pids
    By pavetim in forum Gen III V8 Specific
    Last Post: January 24th, 2011, 05:30 AM
  4. Calc Pids
    By minytrker in forum External A/D inputs
    Last Post: February 19th, 2010, 05:39 AM
  5. CALC pids
    By purrvert in forum General
    Last Post: October 25th, 2005, 12:32 AM
