Results 1 to 10 of 15
Thread: Help to make Calc PIDs in V8
    May 2010
    Default Help to make Calc PIDs in V8
    Hello EFI Live team
    I hope there will be a tutorial to help make Calculated PIDs in V8
    Thanks in advance
    EFILive Tuner
    I thought the was a thread which briefly showed how, but I can't find it I'll look for it.
    In the meantime see attached example file from my folder C:\Users\joecar\Documents\EFILive\V8\Config (remove the .txt from the end of the filename).
    Code:
    [Groups]
    GLOBAL=Global Functions
    WO2SER=Wide Band O2 Sensors (Serial-Comms)
    WO2CAN=Wide Band O2 Sensors (CAN-bus)
    [GLOBAL]
    FUNCTION="Global Functions",factor,0
    [GLOBAL.FUNCTION]
    0=|-- GLOBAL.FUNCTION
    1=|function iff(x,y,z)
    2=|if (x) then return y else return z end
    3=|end
    [WO2SER]
    WO2BEN="Base Efficiency Numerator (Serial-Comms)(Dynamically-Leanest)",factor,3
    [WO2SER.WO2BEN]
    0=|-- WO2SER.WO2BEN
    1=|return iff(pid("WO2LAM1")>pid("WO2LAM2"),pid("WO2LAM1"),pid("WO2LAM2"))*pid("EQIVRATIO")
    [WO2CAN]
    WO2BEN="Base Efficiency Numerator (CAN-bus)(Dynamically-Leanest)",factor,3
    [WO2CAN.WO2BEN]
    0=|-- WO2CAN.WO2BEN
    1=|return iff(pid("WO2S11")>pid("WO2S21"),pid("WO2S11"),pid("WO2S21"))/pid("EQ_RAT")
    Feb 2007
    Hi Joe, which folder does this attachment reside, i put it in C:\Users\Andy\Documents\EFILive\V8\Config. I cant see the pids when i open V8 scan. I can manage calc pids in V7.5, need a push in the right direction
Name:	Screenshot 2018-03-08 21.02.07.png
ID:	21893   Click image for larger version.
Name:	Screenshot 2018-03-08 21.01.46.png
    Post your UserCalculatedPids.ini file here, let me look in it...
    Feb 2007
    Hi Joe, downloaded and moved your UserCalculatedpids.ini file to the said location, I dont see the calc pids show up up in the right hand pane nor the pid editor, i took some screen shots
Name:	Screenshot 2018-03-09 04.38.53.png
ID:	21898   Click image for larger version.
Name:	Screenshot 2018-03-09 04.36.48.png
ID:	21899   Click image for larger version.
Name:	Screenshot 2018-03-09 04.37.10.png
ID:	21900   Click image for larger version.
Name:	Screenshot 2018-03-09 04.39.01.png
ID:	21901   Click image for larger version.
Name:	Screenshot 2018-03-09 04.41.09.png
Name:	Screenshot 2018-03-09 04.41.13.png
ID:	21903   Click image for larger version.
Name:	Screenshot 2018-03-09 04.42.00.png
    Why not just use the built in Calc PIDs editor?
    In the Scan Window, click the drop down arrow on the [Options] button and select "Calculated PIDs" (or just use the Ctrl+K hot key).
    Calc PIDs in data logs are updated instantly (when you close the calc pids editor, or click [Apply]) , no need to try and understand/edit the calc pid *.ini data files.
    Paul, you meant the down arrow on the [Config] button.
    Yes, I'm getting too old for this...
    Yes, the file UserCalculatedPids.ini correctly resides in that folder C:\Users\Andy\Documents\EFILive\V8\Config
    When you open V8 S&T, click Scan, look over in the RH pane (yellow) Available PIDs, expand Calculated, you should see your pids here.
    Quote Originally Posted by Gelf VXR
    Hi Joe, if i am following correctly, create a group name (up to me), create a pid name (up to me), copy and paste code in its entirety, save job done?
    Yes, pretty much, as long as the syntax of the pasted code is correct...
    when editing the pid equation in V8, there is a button fx Test to check that the pid is correctly syntaxed.
    That button is also available if you double click on a pid in the green pane.
  1. Replies: 1
    Last Post: January 29th, 2015, 11:14 AM
  2. CALC.PIDs
    By COONDOG96 in forum Tips and tricks
    Last Post: January 25th, 2014, 03:03 PM
  3. Can someone help me out with calc.pids
    By pavetim in forum Gen III V8 Specific
    Last Post: January 24th, 2011, 05:30 AM
  4. Calc Pids
    By minytrker in forum External A/D inputs
    Last Post: February 19th, 2010, 05:39 AM
  5. CALC pids
    By purrvert in forum General
    Last Post: October 25th, 2005, 12:32 AM
