Results 1 to 2 of 2
Thread: E38 High Injector Duty Cycle and High Map
    Feb 2009
    Default E38 High Injector Duty Cycle and High Map
    Log_1GCSCSE27AZ210176_0003.efi I was checking to see if I'm Logging the correct PIDs for Injector Duty Cycle Correctly. Its getting up to 237%. Also my Map is running about 80kpa cruising at 75mph. 2010 Silverado 6.2 285-45 r22 Tires on it.
    Nick
    You're using the pids GM.IBPW1/2 and CALC.INJ1/2DC, these are for GenIII.
    You want the pids GM.INJPWB1/2...
    for the INJDC pids you need to define calc pids for them as follows:
    Code:
    *CLC-00-011
    %                  0.0         100.0       .1  "{GM.INJPWB1}*{SAE.RPM}/1200"
    *CLC-00-012
    %                  0.0         100.0       .1  "{GM.INJPWB2}*{SAE.RPM}/1200"
    Code:
    CALC.INJDCB1               F011 CLC-00-011   %                Tuning           "Injector Duty Cycle Bank 1"
    CALC.INJDCB2               F012 CLC-00-012   %                Tuning           "Injector Duty Cycle Bank 2"
    see attached calc_pids.txt.
  1. Injector Duty Cycle.
    By ssdungeon in forum Gen III V8 Specific
    Last Post: September 10th, 2009, 05:50 AM
  2. injector duty cycle
    By minytrker in forum General
    Last Post: September 10th, 2009, 05:24 AM
  3. Logging injector duty cycle with E38?
    By Redline Motorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: August 25th, 2008, 01:12 PM
  4. Injector Duty Cycle??
    By Ponch in forum Gen IV V8 Specific
    Last Post: September 9th, 2007, 02:30 PM
  5. Inj duty cycle too high?
    By Bruce Melton in forum General (Petrol, Gas, Ethanol)
    Last Post: April 8th, 2006, 09:08 AM
