Results 1 to 8 of 8
Thread: Timing and tire spin question
    Mar 2010
    Default Timing and tire spin question
    If I were wanting remove timing to help with traction off the line, what would be the best rpm/map areas to remove the timing? Also, how much timing is safe to remove? This is on a TT 402 cu in, 4l65e C5Z06, using 28/11.5/16 QTP Hoosiers.
    01Z06, A4, Huron Speed Twin 67/66's on a 347
    Dec 2014
    Log launching and find out. Every rig is different.
    Mar 2010
    I've been doing that. I just wanted suggestions on what may be enough and what may be too much. Trying to get in the ball park without hurting anything.
    Oct 2006
    Burst knock retard can be used to help with this, as long as there are no other large changes in airflow during the run.
    The Tremor at AIR
    Mar 2010
    Quote Originally Posted by 5.7ute View Post
    Could you expand on that thought please. Thanks
    Oct 2006
    I have never tried this, but the theory behind it is to allow burst knock to trigger and decay as required at the hit of the throttle.Take a look at the burst knock retard delta airmass table. By logging Delta Airmass which I think you will need to construct a calc.pid for, and populating the table as required, you should be able to retard timing from the hit due to the large spike in Delta airmass. Then tune the decay rate to suit.
    The Tremor at AIR
    That is exactly how BK works.
    ~ posted by phone ~
    Nov 2014
    op asked how much timing was safe to remove? any thoughts?
  1. 2005 ssr speedo quits when tires spin
    By Wichita Dyno in forum Gen IV V8 Specific
    Last Post: July 24th, 2014, 07:42 AM
  2. Lmm question? do they kill the fuel until it sees tire speed?
    By Dragbear in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 21st, 2013, 05:59 AM
  3. 06 1500 hd 6.0 wont spin tires
    By dmaxbowtie in forum General (Petrol, Gas, Ethanol)
    Last Post: December 13th, 2010, 09:58 AM
  4. Tire change for track question
    By SSThunder in forum General (Petrol, Gas, Ethanol)
    Last Post: July 24th, 2007, 02:14 AM
  5. Locked out timing question for boost setup question??
    Last Post: September 13th, 2005, 03:22 PM
