Results 1 to 4 of 4
Thread: E85 AFR's
    Default E85 AFR's
    Hi,
    I have searched the forum and googled with no luck for E85 numbers.
    Is there a EFI Live E85 conversion how to I missed.
    2004 HSV Clubsport LS1 12225074......................STD.........E85
    {B3601} Ratio of Air to Fuel for Stoichiometry......14.63.......9.760
    {B3606} Maximum Enrichment...........................12.947.....7. 515
    {B3607} Open Loop Lean Limit (Idle)..................14.629.....9.700
    Are my E85 numbers in the ball park or what do I change or leave.
    This is a LS1 turbo straight E85.
    Apples
    If you use EQR units then stoich is 1.0000, idle is 1.000, NA PE is 1.175, boost PE is 1.25... regardless of fuel being run.
    ~ posted by phone ~
    Jan 2008
    Sorry for the dumb question. But I'm in the middle of switching to an E85 only tune. If I change over to EQR on 93 oct then all my PE settings get converted as you say ~ 1.25. Then once I fill the tank with ethanol blend all I need to do is change my B3601 to 10.3 or so for E75 and I'm good to go?
    2001 Camaro SS
    Built 370 LQ9, Ported 243s, D-1SC 14 psi. 691 rwhp, 643 rwtq
    Best time: 11.6@124 on nitto drags with a 2.1 60'
    "if you're gonna build a time machine into a car, why not do it with some style." Dr. Emmett Brown
    Jul 2003
    Quote Originally Posted by white01ss View Post
    Yes.
    Change to your current stoich. You should go to a P59 ECM and add a sensor to avoid the changing of calibrations.
  1. SM-AFR, DM-6 WIDEBAND AFR GAUGE COMBO good for EFILive Monitoring?
    By Black LS1 T/A in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: January 17th, 2016, 03:11 PM
  2. Commanded AFR not equal to WBo2 AFR at idle.
    By macca33 in forum Gen III V8 Specific
    Last Post: April 6th, 2012, 11:56 AM
  3. E10 and E85 equivlant to gas AFR graph...
    Last Post: February 13th, 2010, 08:13 PM
  4. E85 Os???
    Last Post: July 3rd, 2007, 01:15 AM
  5. Custom O.S. (3) with E85 Commanded AFR
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 17th, 2005, 05:37 AM
