Results 1 to 7 of 7
Thread: VSS Signal style/type ? (pickup question)
    Sep 2004
    Post VSS Signal style/type ? (pickup question)
    Blacky thought somebody here may know.
    I have a question about the VSS signal. Does anybody know if a split ring w/ magnet type pickup would work ? http://www.markwilliams.com/drivesha...CategoryID=266<--- like this
    I swapped my LS1 into a 88 Camaro Drag Car, and am using a th350, and thought this would be te easiest way to monitor driveshaft RPM. I know there are different tailshafts, and adaptors available, but thought maybe somebody would know if that type of signal would be recognizable by the cpu. I know that with EFI Live I can correct the pulses to read correctly.
    Thanks, Jason
    jman812@hotmail.com
    Jun 2005
    The link doesn't work. Is it a hall effect type sensor? I don't *think* those will work.
    Sep 2004
    Quote Originally Posted by technical
    Link fixed
    "Part Number(s): 57644 Magnetically triggered switch normally open and closed with magnet passage. Same as supplied with Racepack Computer Systems. Fits 3/8" diameter hole in mount bracket."
    Thanks for any help.
    'J
    Sep 2004
    Anyone ? Is the stock pickup an open/closed type circuit ?
    Thanks !
    'J
    Jun 2005
    I believe the stock sensor is a pulse motor (maybe not the correct terminology). I don't think those switches will work. But I'm not 100% positive about that.
    Will a 4L60E reluctor wheel fit on a TH350 shaft...?
    Feb 2006
    The 40 tooth reluctor wheel fits on the T350 output shaft. You can use the non-Chevy tailshaft with the large speedometer driven gear boss. The early 4L60-E VSS pick-up will work just fine. The speedo needs to be set up like an automatic, not a manual to work.
    AL
  1. Injector Data for return style fuel system
    By minytrker in forum Gen III V8 Specific
    Last Post: November 26th, 2009, 03:36 PM
  2. Replies: 8
    Last Post: September 9th, 2008, 11:08 AM
  3. Replumbing the PCV pickup point
    By joecar in forum Tips and tricks
    Last Post: March 1st, 2006, 04:07 PM
  4. DTC Type A/B/C, MIL Yes/No
    By Teutonic Speedracer in forum General (Petrol, Gas, Ethanol)
    Last Post: February 27th, 2006, 03:58 PM
  5. Replies: 13
    Last Post: November 22nd, 2005, 10:14 AM
