Results 1 to 7 of 7
Thread: Unable to register flashscan v 1.2
    Jun 2018
    Default Unable to register flashscan v 1.2
    I am attempting to use a Flashscan v 1.2 unit I bought second hand. When trying to flash a PCM I am receiving the error “The attached device is a Scan Only device” I believe I have followed the proper steps to license the device from my Blue License Registration card. Please see the screenshots below and let me know what I am doing wrong.
ID:	22182   Click image for larger version.
ID:	22183   Click image for larger version.
    The "Personal: license was deprecated years ago and was been replaced with the "Commercial" license.
    I'll "PM" you a commercial license in a few minutes...
    Jun 2018
    Thanks Blacky!! I just installed it however I am at work and will test a flash once I get home. How many PCM's will I be limited to? Also can you help me fix my account I accidentally used my email address as my user name. I don't see a way to change it in my settings.
    The V1 device supports up to 25 controllers, each additional controller requires a PCM license purchase here: http://www.efilive.com/licenses/tuni...v1-pcm-license
    You can check how many have been used using the V7.5 Tune Tool software: Help->FlashScan V1 PCM licensing...
    I'm not sure if I can change your username, but if I can, what do you want it changed to?
    Jun 2018
    I am still unable to flash a PCM after putting the new licencing in. See the screenshots below. Help->FlashScan V1 PCM licensing still shows "Personal Scan&Tune" and only 2 PCM licences. If you could change my username to moatsman5000 that would be great.
    Quote Originally Posted by kevin.l.moats@gmail.com View Post
    Sorry, my mistake. It's been so long since I've upgraded a V1 I forgot to send you the activation code to upgrade the actual V1 device to "Commercial". Sending that now...
    Jun 2018
    Thanks!! It is working as expected now. Just flashed my first PCM. Removed VATS now I have a ton of reading to do to start tuning. Thanks again for supporting such an old platform and getting my username changed.
  1. Won't register
    By pavetim in forum FlashScan V2
    Last Post: September 7th, 2016, 08:19 PM
  2. Can't get vin to register on v8
    By MWunsch995 in forum FlashScan V2
    Last Post: January 13th, 2016, 01:15 AM
  3. How to register?
    By VeeAte in forum FlashScan V2
    Last Post: February 16th, 2010, 12:38 PM
  4. Register another truck
    By duramaxdaddy29 in forum Duramax LB7
    Last Post: June 3rd, 2008, 03:42 PM
  5. FlashScan Tune - Register PCM Error
    By highperf in forum General (Petrol, Gas, Ethanol)
    Last Post: April 17th, 2005, 11:41 AM
