Results 1 to 8 of 8
Thread: Problems connecting to v1, intermittent connection problems
    Member badls1's Avatar
    Dec 2009
    Default Problems connecting to v1, intermittent connection problems
    I have flashscan v1 that I have been using for the past 3+ years. Recently when logging a Camaro I was tuning I got a vehicle connection error. Assuming it was a problem with the obd2 port I tried it on my car, verifying power at the obd2 port and still had the same issue. It will connect occasionally for 10-15 seconds and log data very slowly, then lose connection. Now when trying to connect it will not validate any internal PID's. The cable from Flashscan to obd2 port ohms out fine. I assume this is some sort of software issue? Anyone have any ideas? This is running the latest version of v7.5.
    Thanks,
    Curt
    1989 Notch l Forged 5.3L l PT91.5 l th400
    SBE 4.8L l S475 l th400 8.62@156 (old setup)
    Goto the F12 Console tab and copy all the text (ctrl-A) and post it here.
    ~ posted by phone ~
    Dec 2009
    I ended up uninstalling all efilive and reinstalling and it seems to be working fine now.
    ok
    ~ posted by phone ~
    Dec 2009
    and the issue is back. cant even flash a tune or read a tune. tried multiple pcms.....
    Can you verify that the V1 powers up when plugged into the OBDII port only? It looks like the PCM isnt communicating with the V1, but your PC can communicate with the V1. Check your cigarette lighter fuse as well, it's connected to the OBDII port.
    Dec 2009
    Still having the same issue. Thought it was related to the old laptop i was using; new laptop, new EFI Live install, same issue.
    Seems to log fine until i roll into the throttle, boost comes in and it looses connection. After a pull it would reconnect and start logging again.
    I have a log file where you can see the loss of about 6 seconds of logging time and then it reconnects and continues logging (see attached at 16.23.52.126)
    Any ideas?
    Joe - regarding pulling the console text, i need to do that right after it fails to connect? It doesn't seem to be stored in a log file.
    dyno pull 900.efi
    Yes, do it as soon as it fails...
    click cursor on console text, go ctrl-a then ctrl-c and paste the text into a reply to this thread.
  1. Problems connecting
    By pauly24 in forum FlashScan V2
    Last Post: June 29th, 2010, 04:34 AM
  2. V2 Connecting problems
    By 91LS1S10 in forum Vortec V6/V8 Specific
    Last Post: August 24th, 2008, 01:06 PM
  3. Connection problems
    By monaro308 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 18th, 2008, 02:14 PM
  4. Problems connecting with the RR
    By 5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 13th, 2007, 12:55 PM
  5. problems connecting help
    By 87gmc in forum General (Diesel)
    Last Post: January 30th, 2006, 06:38 PM
