Results 1 to 10 of 13
Thread: V1 stopped letting me flash my pcm
    Jun 2017
    Default V1 stopped letting me flash my pcm
    Hey Paul,
    Not sure what is happening with my v1.
    It was working fine aND went out last night to make a change and got a popup saying it is scan only and to upgrade to scan and tune.
    License file is the one you had sent me a long time ago and was working with the latest version of efilive.
    Nothing changed, maybe a windows update.
    Strange since I've been using this laptop for flashing for years, and even flashed a short time ago. Just out of the blue it says I have scan only.
    I can read the pcm and save to a file no problem, it comes up with no errors connecting with the scanner and tuner, and then run either the test or flash I get the popup.
    Any help would be appreciated.
    Go Help->Register EFILive and post a screenshot.
    ~ posted by phone ~
    Jun 2017
ID:	21139Click image for larger version.
    ~ posted by phone ~
ID:	21137   Click image for larger version.
    Jun 2017
    0:55:27.560: Scanning for EFILive FlashScan V1 USB
    20:55:27.575: Autodetect interface ...
    20:55:27.638: Interface firmware version: 1.2.17
    20:55:27.653: Connection to [FSP] interface is OK
    20:55:27.653: Current protocol set to: "SAE J1850 VPW"
    20:55:27.653: Autodetect PCM...
    20:55:27.716: Connection to PCM is OK
    20:55:27.716: Current protocol: "SAE J1850 VPW"
    20:55:27.762: Interface firmware model: FSP
    20:55:27.778: Interface firmware version: 1.2.17
    20:55:27.794: Interface firmware date: Jan 18, 2005
    20:55:27.825: FlashScan serial number: 003480582106
    20:55:27.934: Getting status...
    20:55:27.981: Status: OK.
    20:55:44.720: Disconnecting ...
    20:55:44.735: Disconnected
    20:55:45.453: Scanning for EFILive FlashScan V1 USB
    20:55:45.468: Autodetect interface ...
    20:55:45.531: Interface firmware version: 1.2.17
    20:55:45.546: Connection to [FSP] interface is OK
    20:55:45.578: Interface firmware model: FSP
    20:55:45.609: Interface firmware version: 1.2.17
    20:55:45.624: Interface firmware date: Jan 18, 2005
    20:55:45.656: FlashScan serial number: 003480582106
    20:55:45.671: Disconnecting ...
    20:55:45.702: Disconnected
    Quote Originally Posted by Ulosst View Post
    Hey Paul,
    The "Personal Scan and Tune" license has been discontinued.
    A free upgrade to Commercial Scan and Tune is available. Send your serial number to me at paul@efilive.com and I'll email back the upgrade code.
    Don't worry about sending an email, I obtained your serial number from the traces above.
    I have emailed you an activation code to upgrade your V1 to a Commercial Scan and Tune.
    Jun 2017
    Thanks Paul, just sent via email.
    Derrick
    Jun 2017
    working now, thx
    Jan 2020
    I know this is an old post, but I'm in a similar place. Upgraded to Commercial, registered product, and flash still fails. Here is what I see:
    Status shows a green check, so I selected Test for the first time.
    It ran through Simulate ECM memory erase
    Then Simulate reflash and 2K of 224K
    Reflash failed ... aborting
    Total time 00:11
    Data compressed 29.2%
    Clear emission related DICs
    FSP interface okay
    Auto detect PCM
    PCM not detected
    Help!
    Quote Originally Posted by Loader. View Post
    Total time 00:11
    FSP interface okay
    Auto detect PCM
    PCM not detected
    Help!
    What PCM type are you using?
    Can you check to see if a trace file was created in the folder \Documents\EFILive\V7.5\Bug Reports. The trace file will be named something like "20190926_120523_download.blx"
    Where the numbers refer to the date/time that the trace file was created.
    If the trace file exists, please email it to me paul@efilive.com.
    Are you able to log data from the PCM - i.e. do any communications between FlashScan and the PCM work?
  1. Random lean spikes after letting off throttle
    By ferocity02 in forum Gen III V8 Specific
    Last Post: April 2nd, 2014, 05:22 AM
  2. help. stopped during flash locked ECM
    By SGFastMax in forum Duramax LB7
    Last Post: October 29th, 2010, 04:33 PM
  3. PCM Flash to Grand-AM Cup PCM
    By Rusty in forum Gen III V8 Specific
    Last Post: January 5th, 2009, 09:58 PM
  4. Knock when letting off throttle.
    Last Post: March 6th, 2005, 05:46 PM
