Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: P1635 code after header install 2002 Corvette
  1. #11
    Feb 2016
    Log these: SAE.MAP, GM.EOPS, CALC.EOPS
    So it seems that my MAP is updating as it should but the Vref voltage is wrong and hence the MAP reading is wrong. It also seems that my oil pressure voltage is the same regardless of RPM or if I am running or not. I probably have a short in my oil pressure sending unit that is affecting my MAP sensor.
  2. #12
    Corvettes have EOP wired to PCM (I'll check s 2002 Y-car wiring diagram later tonite), so it should be working...
  3. #13
    Feb 2016
    So I took of the intake manifold and both my EOP sensor and my MAP sensor have a full 5V reference voltage. This means that either one or both of the sensor is bad(at least I think). Does that make sense?
  4. #14
    Follow the disgnostic chart I posted above.
    ~ posted by phone ~
  1. 2002 corvette stock
    By oreobadr in forum Gen III V8 Specific
    Last Post: January 11th, 2017, 08:33 AM
  2. First log after long tube header install, recommendations?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 14th, 2011, 03:14 PM
  3. Anyone done a Corvette 2000 OS to 2002 OS change?
    By aleco99 in forum Gen III V8 Specific
    Last Post: September 24th, 2007, 01:24 AM
  4. 2002 Corvette Z06 Tune
    By CGTMS in forum Gen III V8 Specific
    Last Post: August 23rd, 2007, 04:00 AM
  5. 2002 corvette tune
    By slickvic in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: March 1st, 2006, 04:39 PM
