Results 1 to 8 of 8
Thread: looking for nv4500/6.0 tune for 1mb pcm
    May 2008
    Default looking for nv4500/6.0 tune for 1mb pcm
    I put a nv4500 (5 speed) and 6.0 from a silverado in my jeep, its running with a hacked together 6.0/4l80 and 4.8/5spd tune. it all works but i am getting some stalling when shifting/stopping. i have been comparing some manual/auto tunes and have an idea on what to change but starting with the correct tune for the drive train will be 1000% easier..
    Put a 6.0/manual tune in the PCM and start with that. Finding a 5MT trans segment might be tough and you have to go with a 6MT from like a Vette then change the ratios.
    May 2008
    i am looking for factory 5mt / 6.0 truck tune, they exist, this drive train came from one of those vehicles.
    Post your file up, sounds like you need to do a RAFIG process and dial the idle airflow in. Start with the tutorial on this forum and copy the values from a 5MT tune as a baseline.
    What year/OS are you running?
    If this doesnt work, worst case you could get a VIN from a truck that has the engine/trans setup you want and find someone to flash it with GM SPS and read it out.
    Apr 2011
    I'm pretty sure I have one for an '03 -- Just have to get to it.
    Keep in mind that with the MT tune the CPP (clutch pedal position) switch selects the P/N or IG idle airflow tables, so you have to tune both (RAFIG and RAFPN) as Erik said.
    Dec 2014
    Here's your unicorn.
    2005 Manual 6.0 Truck.ctz
    Apr 2011
    Here's another in BIN format -- not really sure where it specifies auto/manual. Wouldn't mind knowing!2004_6.0L_LQ4_4x2_Manual_STOCK.zip
  1. 1mb LS1B PCm Not detected
    By auspeed in forum Gen III V8 Specific
    Last Post: July 8th, 2015, 04:36 PM
  2. 512kb tune, full flash to 1mb pcm
    By Eric in forum Gen III V8 Specific
    Last Post: December 29th, 2014, 11:38 AM
  3. Replies: 19
    Last Post: March 19th, 2014, 02:16 PM
  4. Conversion of 1mb pcm to 512kb pcm? What is needed?
    By Highlander in forum RoadRunner Real-Time PCM Emulator
    Last Post: February 13th, 2012, 07:25 AM
  5. COS for VZ 1MB PCM
    By limited cv8r in forum Custom Operating Systems
    Last Post: May 24th, 2010, 01:00 AM
