Results 1 to 6 of 6
Thread: Is it possible to change from DBW to DBC
    Lifetime Member wesam's Avatar
    May 2010
    Default Is it possible to change from DBW to DBC
    Is it possible to change Corvette C5 2004 from DBW to DBC ?
    EFILive Tuner
    Jul 2003
    Yes... it is super simple on the system section.
    Mar 2009
    I'm curious why you'd want to though? It's easier to live with a big TB with DBW as oppsoed to DBC and you can adjust throttle response with a click of a mouse. I'm actually wanting to do the opposite.
    May 2010
    Quote Originally Posted by Supercharged111 View Post
    The problem with DBW and with high boost you will never solve the REP problem and will keep haveing a problems with p1516 code
    EFILive Tuner
    Nov 2014
    what is "high boost" and what is the rep problem?
    REP = reduced engine power
    this happens when the tune causes the ETC/MAP sanity tables to be exceeded, usually throws a DTC (e.g. P1516).
  1. DBC to DBW.
    By camaro68 in forum Gen III V8 Specific
    Last Post: August 17th, 2017, 02:42 AM
  2. DBW - DBC conversion 08 VE Commodore (E38 ECU)
    By dazzak75 in forum Conversions / Aftermarket Parts
    Last Post: May 4th, 2016, 08:18 AM
  3. Flex fuel DBC OS
    By turbo_bu in forum Gen III V8 Specific
    Last Post: March 24th, 2015, 10:44 AM
  4. DBW to DBC cable conversion
    By Dave_62 in forum Gen III V8 Specific
    Last Post: October 18th, 2013, 01:37 PM
  5. Need a little help with a DBW to DBC conversion
    By JUSTASBC in forum Gen III V8 Specific
    Last Post: September 3rd, 2011, 10:19 AM
