Results 1 to 8 of 8
Thread: Went to a 2 bar, now the trans line pressure is maxxed out
    Mar 2009
    Default Went to a 2 bar, now the trans line pressure is maxxed out
    As the title states, I went 2 bar because of the blower on my 1500 I just installed and now every gear snaps your neck (part throttle and WOT alike). It's going to snap hard parts too if I don't figure out what's wrong. What do I need to capture to figure this out? There are no large vacuum leaks that I can see and the MAF is plugged in in its original home (Whipple) so no changes to its characteristics. Still has the screen too.
    Mar 2009
    And after dropping the IFR from around 4.9 to 4.5 the truck is happier, AFRs are better, response is better, LTFTs are much closer to where they were before the swap, and now the trans shifts normal? Was it the IFR change, did the MAF decide to play ball, or was it me finally getting the blower bypass valve vacuum line situation right? Either way the truck is awesome now! Just need to give it a calc.vet so I can unrape the PE. Only seeing small amounts of KR on the initial guesstimated tune, I'm very pleased with how it's turning out so far though I am ready to pulley down now.
    Post your before and after tune files and any logs (identify them as from which tune they came from).
    Mar 2009
    There are max pressure enablers in the transmission segment that have to be disabled. Might want to confirm they are done. It should be the custom os tutorial.
    Mar 2009
    I don't remember the max pressure enablers being in that COS tutorial but that doesn't mean I missed them. I should say I'm not MAFless. Here are the tunes and logs. I know I'm way off, it seems to pull a lot at low load and less at higher loads. Odd. Tune 1 goes with log 1 and tune 2 goes with tune 2. I still have the calc.vet parameters loaded but can't do one until I settle on an IFR. Problem is, when I set the IFR correctly the truck has such a terrible tip in off idle it's basically undriveable. Once off idle, tip in is fine. I can watch the wideband go full lean when I poke it from a stop, I'm totally lost on that one.
    411 Whipple V1.tun
    411 Whipple V2 IFR Change.tun
    Whipple Log 1.efi
    Whipple Log 2.efi
    Are you seeing any DTC's...?
    Mar 2009
    Just the evap and something else that isn't hooked up.
    Mar 2009
    I guess I'm not worried so much about the trans now that it only did it that one run. I'm now far more concerned with how to kill this off idle lean spot I have because it prevents me from settling on an IFR which prevents me from running a calc.vet, going after the timing, and tweaking the IAT as I suspect I'll need to let it pull timing more aggressively.
  1. 4L80E with Trans Brake, no reverse, line pressure?
    By tdmkr496 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 20th, 2014, 06:27 AM
  2. 6.0 LS2 / T42 GTO - make trans line pressure TPS dependant?
    By 02CCSB in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 24th, 2013, 03:25 AM
  3. line pressure in efilive
    By Cool28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 12th, 2012, 07:20 AM
  4. line pressure
    By dezzi in forum Allison 5 & 6 Speed
    Last Post: January 18th, 2010, 02:59 AM
  5. Problems with Line Pressure
    By goldbergv95 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 5th, 2009, 05:41 AM
