Results 1 to 6 of 6
Thread: steady state lean then rich all when commanded same afr
    Apr 2006
    Default steady state lean then rich all when commanded same afr
    weird issue that ive never come across, drive the car steady state 40 mph the commanded afr is 14.63 inj pw is 3.6ms then with no change to throttle position or load or rpm it drops to 2 ms, loaded a factory tis flash into the pcm and it does the same thing, attached is a base tune with it set to maf to get the maf dialed in, then just a factory tis flash to try,
    anyone ever see this
    does it with the factory flash also
    Log_2G1FP22G522146951_0003.efi
    LS1B 12212156 base_0000.ctz
    LS1B 12212156.ctz
    Log_2G1FP22G522146951_0002.efi
    Log_2G1FP22G522146951_0000.efi
    I'll take a look later...
    Apr 2006
    thanks this ones throwing me for a loop, im sure im just overlooking something, crazy thing is it does it with the stock flash
    Your LTFT's are cycling to 25%... looks like you have an airleak common to both banks, i.e. the at intake manifold or after the MAF.
    Apr 2006
    it does it in open loop also
    either way, something is wrong.
  1. Commanded Rich AFR
    By pdyoung in forum Gen IV V8 Specific
    Last Post: March 29th, 2016, 04:20 AM
  2. My commanded AFR is changing rich on me!
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 14th, 2009, 02:38 PM
  3. AFR not what Commanded- lean no matter what i change
    By nonnieselman in forum Gen III V8 Specific
    Last Post: April 13th, 2009, 04:52 PM
  4. Commanded AFR goes lean at high MAP value
    By wadesns in forum General (Petrol, Gas, Ethanol)
    Last Post: March 5th, 2009, 04:24 PM
  5. Lean spikes commanded vs actual AFR
    By billyjo in forum Custom Operating Systems
    Last Post: January 24th, 2008, 05:58 PM
