Results 1 to 4 of 4
Thread: MAP files help
    May 2006
    Default MAP files help
    Is there any where to get pre built maps? For some reason im having a hard time building maps and having them work right.
    Oct 2005
    There was a video tutorial floating about from blackss which showed how to make a map.
    You have to make sure you have selected the correct pids that you want to use in the map. You can copy labels from a table and paste them in or make them manually. What errors are you getting?
    I can post a few maps like for autotune etc, but they are so useful its better you figure it out yourself. Just let us know where you think you are going wrong or what the error is etc and hopefully we will get you there.
    2014 VF SV LS3 Maloo.
    May 2006
    Well, i seem to get 3.2 degrees of KR. It happens when im at a light and kind of launch it. Not like a race tracl launch, but more of a take off from the light real quick launch. I dont see any when im at WOT, but i havnt been there much yet (little scared after cam install LOL ) What kind of map can i put together to get this monitored and fixed? Also i have some light surging at around 1400 rpms or so. I have read i might need more spark, maybe less fuel? What would be a good map to build to check this out. O yeah and im reall new at this so dummy it up as good as you can for me THX for the help.
    AB
    Jun 2005
    Open spark map in Tuner.
    Highlight the entire table in Tuner.
    Hit Shift+Ctrl+C (copy with labels).
    Create new map in Flashscan (Ctrl+Enter).
    On the column tab, hit 'paste labels' and select the PID listed in the tuner. In this case, you want GM.DYNCYLAIR_DMA.
    On the row tab, hit 'paste labels' and select the appropriate PID listed in the tuner. In this case, you want SAE.RPM.
    On the data tab, select the PID you wish to log. In this case, GM.KR (aka Retard due to Knock).
  1. '09 E85 6.2L files ?
    By gmh308 in forum Gen IV V8 Specific
    Last Post: November 29th, 2008, 10:32 AM
  2. Where are the .dtc files...?
    By joecar in forum FlashScan V2 BB Logging
    Last Post: October 20th, 2008, 01:39 PM
  3. Where did all my files go?
    By Ira in forum FlashScan V2 BB Logging
    Last Post: December 5th, 2007, 05:24 PM
