Results 1 to 10 of 19
Thread: creating calc_pids
    Jun 2017
    Default creating calc_pids
    Hey all,
    I`ve been trying to create 3 different calc_pids using version 7.5. I`m using the calc. VE tuning tutorial info and am trying to make the three it says to create. "LTFT AVERAGE" "LTFT BEN" AND THE "CALC VE TABLE" For the life of me I can`t seem to figure it out. I put it in exactly as it says and it never comes up in the scan tool. I always close the scan tool before I try to make any. I`d appreciate any help.
    Thanks!!
    Aug 2016
    Make sure you're editing the correct text file, I had one in the installation folder and one in another folder. Changing one did nothing, changing the other actually added my PIDs. I think it was under Users/AppData or something like that.
    Sent from my Nexus 5X using Tapatalk
    Jun 2017
    # File details
    # This section defines various details about the file format.
    *FILE
    #Parameter Value Description
    VERSION 7.1.1 File version
    DECSEP . Decimal separator used in this file
    # Units
    *UNITS
    #Code System Abbr Description
    None None "" "No units"
    # Add slot definitions here
    #------------ ------------- ------------- ---- --------------------------------------------*CLC-00-001
    % -25.0 25.0 .2 "({SAE.LONGFT1}+{SAE.LONGFT2})/2
    CALC.LTFT F001 CLC-00-001 % TUNING "LTFT AVERAGE
    Jun 2017
    I`m under the User Configuration, I can copy and paste one from the LS1 tech forum and it shows. But any I hand enter never show.
    Aug 2016
    You're editing them in the text file outside of EFILive, right?
    Jun 2017
    Quote Originally Posted by pinstripebob View Post
    Yes this is what i see. The LTFT Average both banks works. The LTFT Average does not
    # File details
    *FILE
    # Units
    *UNITS
    *CLC-00-015
    % -25.0 +25.0 .1 "({SAE.LONGFT1}+{SAE.LONGFT2})/2"
    CALC.LTFTTOTAL F015 CLC-00-015 % (Calculated) "LTFT Average Both Banks"
    # File details
    *FILE
    # Units
    *UNITS
    *CLC-00-001 -25.0 25.0 .2 "({SAE.LONGFT1}+{SAE.LONGFT2})/2
    CALC.LTFT F001 CLC-00-001 % Tuning "LTFT AVERAGE"
    Looks like you added two calc_pids.txt files together (appended one after the other, so that the sections appear twice), this does not work...
    instead you have to merge the two files together (merge each of their sections so that they appear once only).
    You said "Calc.VE" above... this has been replaced with "Calc.VET" see here: Calc-VET-correcting-MAF-and-calculating-VE-(in-single-log)
    and use the calc_pids.txt file from there (see post #1).
    Jan 2013
    I feel like this thread is the most relevant to what i'm struggling with too,
    i can't seem to come up with what i believe are all the correct pids, i don't have on the list copied from Joecars last reply above( the "calc.VET" tutorial) i've copied and added that calc_pids.text file to the scan tool, but i don't have 5 of the 24 pids shown with this tutorial and i can find them anywhere to add
    CALC.LTFTBEN
    CALC.WO2BEN
    CALC.SELBEN
    CALC.VET
    CALC.VEN
    I've looked at this over and over again, and it seems pretty straight forward, copy the text file... copy the pid list...clear the trims.. etc etc... for the life of me i can't seem to get this set up right. has something changed in the pid list that i don't need these? that dosn't sound right. what am i doing wrong
    thanks for any help
    1. Did you copy the calc_pids.txt file to the folder C:\Users\<you>\Documents\EFILive\V7.5User Configuration...?
    2. In the scantool, goto the PIDs tab, click on the heading ("Parameter") of the right-hand column (this sorts on this column)... then scroll down looking for those pids by name.
    3. Post screenshots.
  1. Creating new vehicle file
    By vilant in forum EFILive V4
    Last Post: February 18th, 2013, 03:24 PM
  2. Problems Creating Definiton File
    By technovative in forum EFILive V4
    Last Post: October 27th, 2010, 05:24 PM
  3. creating a script
    By SGFastMax in forum Duramax LB7
    Last Post: June 10th, 2009, 08:26 AM
  4. Creating a one column table.
    By 2002_z28_six_speed in forum General
    Last Post: August 5th, 2007, 09:56 AM
  5. Creating/editing macros
    By botteman in forum EFILive V4
    Last Post: June 1st, 2007, 05:56 PM
