Results 1 to 2 of 2
Thread: Stalls when shifted to drive
    Jun 2013
    Default Stalls when shifted to drive
    I'm working on a 2004 5.3 + 4l60e with electronic throttle swapped into an old gmc pickup. When I shift into gear or turn the ac on the idle drops way down. When this happens timing goes right to 30 deg. and the e throttle closes a bit. The same thing happens while driving and the vehicle comes to a stop. It seems like the throttle should stay put or open a little instead. I can't figure out what tables control this. Any help I get would be appreciated.nbs idle issue_0001 AC and purge.ctznbs idle issue 2.efi
    You might have to add to the idle IG airflow table... ( I should have asked: do you have the CPP switch connected...? )
  1. 408 stroker stalls when coming to a stop
    By fat333 in forum Custom Operating Systems
    Last Post: March 7th, 2012, 08:23 PM
  2. Low speed, full lock on steering, stalls!
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: April 9th, 2009, 11:29 AM
  3. Stalls when put ingear
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 10th, 2007, 12:42 PM
  4. Cold Start: Starts and stalls...
    By 808ws6 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 20th, 2007, 08:34 PM
  5. Idles/drives great, stalls in reverse
    Last Post: August 8th, 2006, 08:58 AM
