$0025 |
Can't get semaphore for control of
EFILive_Hapi |
Multiple applications attempted to
communicate with FlashScan or AutoCal
simultaneously. |
Usually each message to/from FlashScan or
AutoCal only takes a few tenths of a second so
messages from multiple applications can usually
be handled transparently by queueing the
messages for a few tenths of a second.
When a long running command (like updating
the firmware) is in progress, waiting a few
tenths of a second will not usually resolve the
conflict and the attempt ultimately fails.
After receiving this error it is recommended
that you wait for the other application to
compete its task, then re-do, re-fresh or re-start
whatever task you were attempting.
In rare circumstances it may be necessary to
use Windows Task Manager to end the
EFILive_Hapi.exe process.
In ever rarer circumstances, if the USB driver
has failed then it may not be possible to end the
EFILive_Hapi.exe process, in that case
unplugging all FlashScan and AutoCal devices
may resolve the problem, otherwise rebooting
the computer may be the only option. |
