Results 1 to 7 of 7
Thread: URGENT HELP, CANT READ E38,E67,T43, ERROR $0101: No data received
    May 2012
    Default URGENT HELP, CANT READ E38,E67,T43, ERROR $0101: No data received
    Some days ago i tried to read a tune from a car im working on, i couldnt, it was a E38, today i tried to read an E67 and couldnt neither, tried to read a T43 and same results,, it does detect the ECM, read codes, delete codes, log, etc but i cant read the tune.. i did tried to read and tune a LS1B PCM and it did was possible, so i think there is a problem on the software side or the canbus hardware i dont know, but i really need to fix this, how can i diagnose this? have a couple of cars here i really need to tune, any help will be apreciated.
    May 2012
    who should i contact about this?
    Mar 2009
    Are you using V7 or V8?
    May 2012
    I tried both, same results, updated both same results, but it does detect the pcm, and i can log, and read codes, but it will not read the tune, (E38,E67, i tried those 2 pcm, ).. but i can read and tune LS1B pcm.
    With V7 post the text log you see while reading.
    ~ posted by phone ~
    Jun 2017
    Default T43 0101 error "no data received"
    Hi
    I have the same problem... I have tried to read T43 with 8.2 and it says 0101 error "no data received"
    With 7.5 I can get it read but after 15 sec countdown it cant be modified with 7.5, it says maybe with 8.2 but all calibrations and everything on left side are "unknown"
    here is copied 7.5 text:
    22.05.39.682: Scanning for EFILive FlashScan V2 HAPI
    22.05.39.703: Autodetect interface ...
    22.05.39.846: Interface firmware version: 2.7.113
    22.05.39.856: Connection to [FSV2] interface is OK
    22.05.39.871: CAN-VPW Bridge Activated
    22.05.39.936: Current protocol set to: "ISO 15765 CAN"
    22.05.39.945: Autodetect TCM...
    22.05.39.978: Connection to TCM is OK
    22.05.39.991: Current protocol: "ISO 15765 CAN"
    22.05.40.107: USB driver version: 2.8.40
    22.05.40.120: USB library version: 3.2.7
    22.05.40.144: Interface firmware model: FSV2
    22.05.40.165: Interface firmware version: 2.7.113
    22.05.40.187: Interface firmware date: helmi 19, 2017
    22.05.40.203: FlashScan serial number: 005001074033
    22.05.40.215: FlashScan license number: 005001074033
    22.05.40.228: FlashScan alternate license number: 005001074033
    22.05.40.364: Getting status...
    22.05.40.414: Status: OK.
    22.05.43.783: Disconnecting ...
    22.05.44.315: CAN-VPW Bridge Deactivated
    22.05.44.335: Disconnected
    22.05.44.999: Scanning for EFILive FlashScan V2 HAPI
    22.05.45.029: Autodetect interface ...
    22.05.45.186: Interface firmware version: 2.7.113
    22.05.45.205: Connection to [FSV2] interface is OK
    22.05.45.332: USB driver version: 2.8.40
    22.05.45.353: USB library version: 3.2.7
    22.05.45.379: Interface firmware model: FSV2
    22.05.45.407: Interface firmware version: 2.7.113
    22.05.45.434: Interface firmware date: helmi 19, 2017
    22.05.45.463: FlashScan serial number: 005001074033
    22.05.45.492: FlashScan license number: 005001074033
    22.05.45.517: FlashScan alternate license number: 005001074033
    22.05.45.565: Disconnecting ...
    22.05.46.108: CAN-VPW Bridge Deactivated
    22.05.46.128: Disconnected
    22.05.46.796: Scanning for EFILive FlashScan V2 HAPI
    22.05.46.828: Autodetect interface ...
    22.05.46.970: Interface firmware version: 2.7.113
    22.05.46.991: Connection to [FSV2] interface is OK
    22.05.47.017: CAN-VPW Bridge Activated
    22.05.47.098: Current protocol set to: "ISO 15765 CAN"
    22.05.47.119: Autodetect TCM...
    22.05.47.159: Connection to TCM is OK
    22.05.47.185: Current protocol: "ISO 15765 CAN"
    22.05.47.315: USB driver version: 2.8.40
    22.05.47.338: USB library version: 3.2.7
    22.05.47.365: Interface firmware model: FSV2
    22.05.47.393: Interface firmware version: 2.7.113
    22.05.47.420: Interface firmware date: helmi 19, 2017
    22.05.47.449: FlashScan serial number: 005001074033
    22.05.47.477: FlashScan license number: 005001074033
    22.05.47.503: FlashScan alternate license number: 005001074033
    22.05.47.658: Getting status...
    22.05.47.701: Status: OK.
    22.05.48.492: Bootloader version: T43a_v1.1R (0476-67C4)
    22.05.48.507: Preparing TCM for reading flash...
    22.05.48.539: TCM seed is: $5F91
    22.05.48.556: Unlock attempt 1 of 1
    22.05.48.683: Initializing TCM...
    22.05.49.917: Initializing TCM, step 1 of 4
    22.05.49.932: Initializing TCM, step 2 of 4
    22.05.51.166: Initializing TCM, step 3 of 4
    22.05.53.602: Initializing TCM, step 4 of 4
    22.05.54.045: Initializing bootloader...
    22.05.54.311: Initializing bootloader, step 1 of 3
    22.05.54.640: Initializing bootloader, step 2 of 3
    22.05.54.971: Initializing bootloader, step 3 of 3
    22.05.55.989: TCM ready for reading flash.
    22.05.56.112: ST M58BW016xB - 2MB
    22.05.56.127: CPU Type: MPC561/MPC562
    22.05.57.688: Total time: 00.00
    22.05.57.701: Rebooting TCM... (please wait up to 8 seconds)
    22.06.00.818: Waiting for TCM to complete reboot process... (Retry 1 of 8)
    22.06.02.839: Waiting for TCM to complete reboot process... (Retry 2 of 8)
    22.06.04.863: Waiting for TCM to complete reboot process... (Retry 3 of 8)
    22.06.06.881: Waiting for TCM to complete reboot process... (Retry 4 of 8)
    22.06.08.899: Waiting for TCM to complete reboot process... (Retry 5 of 8)
    22.06.10.918: Waiting for TCM to complete reboot process... (Retry 6 of 8)
    22.06.12.937: Waiting for TCM to complete reboot process... (Retry 7 of 8)
    22.06.12.963: TCM has booted successfully...
    22.06.13.982: Clear emisison related DTCs...
    22.06.16.035: Autodetect interface ...
    22.06.16.166: Interface firmware version: 2.7.113
    22.06.16.183: Connection to [FSV2] interface is OK
    22.06.16.202: Autodetect TCM...
    22.06.16.232: Connection to TCM is OK
    22.06.17.266: Clear DTCs for all modules...
    22.06.19.311: Autodetect interface ...
    22.06.19.441: Interface firmware version: 2.7.113
    22.06.19.457: Connection to [FSV2] interface is OK
    22.06.19.477: Autodetect TCM...
    22.06.19.509: Connection to TCM is OK
    22.06.22.246: Disconnecting ...
    22.06.22.771: CAN-VPW Bridge Deactivated
    22.06.22.786: Disconnected
    22.06.24.556: Loading generic configuration file: sae_generic.txt
    22.06.24.559: User defined calculated PIDs file: calc_pids.txt
    22.06.24.562: Enhanced configuration file: gm_enhanced.prn
    22.06.26.882: Done!
    What could be wrong.. Now I have tested it with new usb cable and uninstalled those EFILive softwares and installed them again.. Still the same problem...
    I'm new user and I have got it read that transmission T43 box 6.6.2017 and I have that original file... I have not made any changes after that..
    -Riku
    Quote Originally Posted by firestrait View Post
    Hi
    -Riku
    If a controller is not yet supported for editing you may get that message. Try using the latest beta software from here: https://forum.efilive.com/showthread...Beta-Release-2
    If you still get that message when using that updated software version, send the tune file to me at paul@efilive.com and I'll check on the support status for your controller.
  1. Error $0281....no data received
    By y2k2z28 in forum FlashScan V2 BB Logging
    Last Post: October 23rd, 2016, 11:08 AM
  2. Script exited with code $0101: No data received
    By paint94979 in forum Duramax LB7
    Last Post: January 14th, 2015, 07:37 PM
  3. Replies: 4
    Last Post: September 3rd, 2013, 08:18 AM
  4. Need help ASAP. $0101 no data recieved error
    By cat_dr. in forum FlashScan V2
    Last Post: May 11th, 2013, 07:23 AM
  5. Autocal Read Error $0101 No data received
    By firehawk in forum AutoCal
    Last Post: April 14th, 2013, 10:36 PM
