Results 1 to 3 of 3
Thread: SAE.MAP reading lower than expected in C7Z06
    May 2010
    Default SAE.MAP reading lower than expected in C7Z06
    Today i was tuning the first 2015 C7Z06 With upper and lower pulley
    I noticed for the first time with KOEO its reading 64 kpa and @WOT 125 kpa ( we are on see level so it should read something like 100-101 kpa KOEO )
    Is there any other PID to log with C7Z06 ? I tried GM.MAP2 GM.MAP3 but non of them seems to work
    Any help will be appreciated
    Thanks in advance
    EFILive Tuner
    Is it the stock MAP sensor? If no did you scale it to read correctly at KOEO?
    May 2010
    Yes atoxk MAP sensor
    And after i asked it seems to be a common issue in C7Z06 and new ZL1
    Even with hp tuners
    EFILive Tuner
  1. SAE.AAT now reading 32
    By dennisscars in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: December 27th, 2011, 10:21 AM
  2. B8034 Has no effect on SAE.LOAD_PCT reading in E67
    By scdyne in forum E37, E38 & E67 PFI ECM's
    Last Post: May 4th, 2011, 09:05 AM
  3. Timing map starting point for PD blower and lower CR
    By MadMaxHSV in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: February 19th, 2011, 09:34 AM
  4. What is the deference between {GM.MANVAC} and {SAE.MAP}?
    Last Post: April 24th, 2008, 06:37 AM
  5. GM.MANVAC vs. SAE.MAP
    By Lennart in forum General (Petrol, Gas, Ethanol)
    Last Post: May 20th, 2007, 04:32 AM
