Page 1 of 19 12311 ... LastLast
Results 1 to 10 of 182
Thread: Big off idle stumble, whatt first? IFR? calc.vet? Something else I'm missing?
    Mar 2009
    Default Big off idle stumble, whatt first? IFR? calc.vet? Something else I'm missing?
    I had a post in the COS forum, but not sure if it goes there or here. If I'm wrong, please advise. I just swapped a marine intake and Whipple supercharger onto my 1998 GMC with 5.7 Vortec. The intake allowed me to run proper injectors, Bosch 0280155811 at 3.5 bar. Stock they flow 36# at 43.5psi, so using this calculator
    http://users.erols.com/srweiss/calcpchg.htm
    and some googling I arrive at 38.888 lb/hr and an IFR of 4.8988. I plugged that in (or something close to it) and the truck fired right up. Trims are off which I wasn't expecting at low load plus I have this NASTY off idle stumble (all other transients are fine) that's worst when the engine is cold. I don't want to go changing a bunch of crap in the wrong order. The truck seems to run better if I fudge the IFR down I believe in the 3.55 range but I assume that's just covering up the real problem. So should I have faith in my IFR math and just go do a calc.vet or is there more than meets the eye when it comes to nailing down a new IFR? Or is there some super simple idle setting I'm totally missing here? My only thought is the addition of some real estate between the engine and the MAF with the supercharger being in the mix now. Physically its location has remained the same as stock.
    411 Whipple V1.tun
    411 Whipple V2 IFR Change.tun
    Get VE/MAF correct.
    Make sure injector data correct.
    I'll look closer later tonite.
    ~ posted by phone ~
    Aug 2013
    There's a lot to look at in this tune file.
    Aug 2013
    Quote Originally Posted by Supercharged111 View Post
    Post a log.
    Mar 2009
    Here's a log.
    Whipple Log 2.efi
    I guess my biggest fear is committing to the mathematically correct IFR, doing a calc.vet, and then realizing that for some reason the IFR is wrong and having to start over again. Sometimes I have KR, sometimes I don't. I really need to get the fuel right on this thing so it's more consistent. I thought I'd pulled enough timing, but I suspect now that since the bypass valve closes before atmospheric pressure is achieved, the IATs are higher at a lower MAP than I'd anticipated. I don't really want to monkey with that until the fueling is correct. I was about to do a calc.vet yesterday, but decided to wait on what I heard in here first. So can I trust that 4.8988 IFR and should do the calc.vet with it and report back? The PIDs that I have currently selected to log are the calc.vet PIDs, but I don't think any of the logs have enough data to try and correct anything. Plus I'm running the wrong IFR to fudge more fuel into it before trims now in a ghetto effort to help the off idle stumble. It's there with a warm engine too, just less bad.
    I'll add that I didn't do the quasi-closed loop operation because the truck is only making 3.XX# of boost which gets me up to 100 kpa on a cool night. I think I'm going to do it though to add a little knock resistance to the range right where the bypass valve closes but I may or may not be exceeding atmospheric.
    Mar 2009
    Quote Originally Posted by statesman View Post
    Could you please elaborate instead of being a douche about it?
    I think he's referring to me looking at it...
    Mar 2009
    It sounds like he's implying that I have a lot of things wrong. If that's the case, why not lay it out instead of making you do it all? If not, I gotbmy panties in a twist over nothing.
    Aug 2013
    It's Aussie humor, and it looks like some people just don't get it.
    Aug 2013
    If I knew what was wrong, I wouldn't need you to post a log.
    Nice panties.
  1. Replies: 83
    Last Post: September 5th, 2023, 11:30 AM
  2. Replies: 4
    Last Post: September 11th, 2013, 02:38 AM
  3. Big VE Difference Between AutoVE & Calc.VET
    By tinindian in forum Gen III V8 Specific
    Last Post: May 9th, 2013, 01:33 AM
  4. Calc.VET, VET Map Average is all 0.0?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 01:20 PM
  5. Slight stumble at idle (intermittent)
    By frcfed347 in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: May 25th, 2011, 10:17 AM
