Results 1 to 5 of 5
Thread: 6l80 Tap Shift
    Apr 2012
    Default 6l80 Tap Shift
    Hi guys, looking for a little help. Have a customer in Dubai with an E38-T43 combo and we are trying to get the tap shift to work. Everything is turned on in the calibration and set up for a wired switch. Can look at the PID's and it says its working, yet no shifting. In order to make it work I think I need to incorporate a BCM, or go to a compatible OS. Am I on the right track or am I missing something? Does anyone have a tune that may work? Can this tune be fixed? Any help is appreciated.T43tuned_0000.ctzE38tuned_0000.ctz
    Feb 2006
    try playing with the shift setting.
    I don't have my laptop in front of me, but there is a bunch of options that list D1 to D6. Try it with anything from D3 to D6.
    On the corvette they use D4 & are direct wired. Commodore platform is normally D6 which initiates the TUTD mode via a resister.
    Apr 2012
    Thanks for the reply, Ive been playing with it a little. I saw that his brake pedal was wired wrong, so its always saying applied. I believe if I can correct this, it should work. Pin 6 in the trans and 9 in the E38 need to have no power when the brakes are applied. I will let you know what happens.
    Mar 2009
    I had the same issue on a jeep swap and had to find a corvette tcm cal in order to get it to work. Make sure you flash in a like tcm OS. There is a thread on here that list them.
    00 Silverado Z71, LQ9 w/ LS3 heads, BTR cam, Whipple 2.9@8#, 4l80E
    Feb 2018
    Solved ?
  1. LLY Tap shift
    By oondy in forum Allison 5 & 6 Speed
    Last Post: December 28th, 2016, 12:57 AM
  2. 2012 Vette 6l80 tune in older trans for faster tap up tap down and rev matching
    By RD in SD in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: January 24th, 2015, 01:36 PM
  3. A6 standalone wiring tap shift?
    By miguelc in forum E37, E38 & E67 PFI ECM's
    Last Post: March 20th, 2013, 03:58 AM
  4. 6l80 won't go into 6th gear above 75mph or so in tap shift mode
    By whypave in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 10th, 2012, 08:07 PM
  5. Faster Tap Shift Response
    By duramaximizer in forum Allison 5 & 6 Speed
    Last Post: January 22nd, 2010, 08:24 PM
Tags for this Thread
