Results 1 to 3 of 3
Thread: ABS Light on / LBZ
    Jul 2007
    Default ABS Light on / LBZ
    So, the ABS light is on. No codes, Fluid full. Can the V2 detect ABS codes from PCM? I changed my front wheel bearings about 2 years ago and did not look at the sensors.
    I am wondering if they are coasted with metal trash or if something else is going on? I noted that when I unplug the passenger sensor, I get no changes. when I unplug the driver's side, the brake light comes on.
    is the V2 right there are no codes or is it not able to read them?
    07 Silverado DMax Classic
    02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
    Old Engine: 1/4mile = 9.6/146 New Engine:?
    EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
    COS5/12212156 For 2002 Z06 Manual Vette
    Dec 2005
    did you alter the PCM tire height ?
    If so, it may be too far from what its happy with
    www.mscservices.net
    Jul 2007
    Quote Originally Posted by GMC-2002-Dmax View Post
    It's got stock sized tires but tune file by kory Willis was adjusted
    Vehicle with aftermarket tune only indicated 75mph at an actual speed of 73mph
    So was adjusted slightly.
    I guess I could flash the stock tune back in.
    I did recently get new tires.
  1. 07 Abs and Break Light
    By 30 RUM in forum Cummins 5.9L
    Last Post: May 25th, 2015, 01:38 PM
  2. ABS/BRAKE light still come on
    By LIL DAVE in forum Tips and tricks
    Last Post: June 7th, 2014, 04:50 AM
  3. Replies: 1
    Last Post: February 2nd, 2012, 10:58 AM
  4. Service brake system w/ABS light and Parking Light on
    By mshirshe in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 13th, 2010, 03:32 AM
