Results 1 to 10 of 15
Thread: ls1 misfire problem
    Sep 2011
    Default ls1 misfire problem
    i have a vz ss ls1 233/242 110lsa and now have a misfire i have seems to be on idle and partial throttle upto about 4000rpm if i accelerate it feels like a vibration through the driveline it doesnt completely drop out any cylinders but i carnt put my finger on it. it seems to be worse when the engine is warm and but it comes and goes while driving. the mixtures are fine but the plugs are black except for 2 cylinders show normal. i have changed the plugs tried a smaller gap also changed leads and checked all conectors coils appear to be ok and injectors and fuel system are definatly good. im not getting any misfire codes have also tried a case relearn. the engine is healthy all cylinders are 180psi and i have between 4-7% cylinder leakage.
    i have tried adding and taking fuel with the scan tool with no luck seems to get worse the leaner it runs and rich makes no difference added timing it makes it worse and taking timing does nothing if i hold the revs up in neutral i can here the misfire very badly. does anyone have any ideas what this problem could be i am at the point of giving up on this car as i am forever spending money on it and havent even had the chance to enjoy it yet
    Aug 2013
    How much do you want for it?
    Dec 2014
    Are the lifters good? Are the push rods hitting the head? Right springs? .......... "They should be, its all new," is not a valid answer.
    Post logs and tune.
    ~ posted by phone ~
    Did this just start happening...?
    ~ posted by phone ~
    Sep 2011
    Lifters and springs were recently changed also its been happening for a while now I have only just realised what's actually going on thought it was just a deivline vibration but it's definitely a misfire. What pids should I log
    Oct 2006
    Are your plugs to cold in the heat range area?
    2006 Trailblazer
    Sep 2011
    No they are standard
    Oct 2006
    Check the ground points on the heads. Front of head drivers side, rear on passenger side.
    The Tremor at AIR
    Oct 2006
    Yeah, body grounds too, PCM and such.
    2006 Trailblazer
  1. ls1 misfire under load (wot)
    By drdarthinvader in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 21st, 2012, 02:26 AM
  2. Problem with my Head/Cam 98 LS1 camaro - files attached
    By blackflag in forum Gen III V8 Specific
    Last Post: May 10th, 2011, 05:27 PM
  3. LS1 PCM (2002 Corvette) problem - starts and dies in 2 secs
    By hIGGI in forum E37, E38 & E67 PFI ECM's
    Last Post: October 4th, 2010, 07:59 PM
  4. Idle problem LS1 w/turbo 350
    Last Post: May 24th, 2008, 01:09 PM
  5. 1998 Corvette LS1 VATS problem
    By Rewire in forum Gen III V8 Specific
    Last Post: September 12th, 2007, 10:36 PM
