Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Support for Cummins CM2150 controller?
    Jan 2015
    Default Support for Cummins CM2150 controller?
    Just wondering if there is any plans to support the CM2150 controller. I believe this would cover 2008-2010 HD cummins/off road.
    Thanks!
    Yes, it would have been supported in the initial release but the checksum methods Cummins used are inconsistent between the numerous reads we have from this ECM. So we decided to hold it off until we can come up with a way to process them all accurately depending on the method each ECM OS uses.
    Dec 2013
    Awesome news.
    I've been on the brink of rewiring to use a different ECM, but it looks like with a little patience the CM2150 will be OK.
    Thank you.
    Dec 2013
    Any news on this?
    CM2150 will not be supported on the first release, maybe early next year instead. We did enable reading for them so we could get some files but that is it.
    The problem is there is three CM2150 versions, CM2150C, CM2150D and CM2150E. The 'E' is very different to the other two, unfortunately by the time we got to the point of making the software stable and not adding in anything else the CM2150's weren't ready to be added.
    Jan 2016
    I have one of these and have the Binary from it would that help at all? also when do you think flashing and editing will be ready once checksums are corrected because that is my current issue as well??
    Thanks, the reading and flashing was ok. As I said the issue was the differences in file structures and checksums between the CM2150C/D and the CM2150E.
    Mar 2011
    In to follow... first truck i get has to be a 2150!!! read was sent to support!
    Joe Kupferschmid
    Daves Diesel Angola
    www.angoladavesdiesel.com
    Diesel and gas tuning
    Personal Vehicles tunes with efi 06LBZ, 05lly, 2002 Z28, 2004 Gto
    Thanks Joe, apologies for the current unsupported status though.
    Oct 2014
    Any update on the 2150's? I've also got a couple of them that are ready to be done.
    Thanks for the help!
  1. Any Cummins support
    By 80superbu in forum General (Diesel)
    Last Post: October 15th, 2018, 02:00 PM
  2. 03-05 Cummins 5.9L Support
    By cindy@efilive in forum Cummins 5.9L
    Last Post: February 7th, 2015, 06:59 AM
  3. Cummins BBL Support
    By KhakiCummins in forum FlashScan V2 BB Logging
    Last Post: April 21st, 2013, 01:36 PM
  4. Will we have support for this controller??
    By Redline Motorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: November 20th, 2008, 04:40 AM
