Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: July 2017, Beta Release 4
  1. #21
    I'm now seeing this on all LS1B tunes I open (I have not opened any LS1A's):
    Is there any way to show what the actual cell values are, maybe a button...?
    ( I know this may not work well with the min/max allowed value displayed )
    Can you send me a file that produces the warning?
    The cells that are out of range should show with a red border. Obviously that won't be visible for cells that are too large, since their cell background will be red as well.
    Try changing the max color for the tables to something other than red.
    Meanwhile I'll work on a better option/color for the cell border when cells are "out of range".
  2. #22
    Quote Originally Posted by LPDTuning View Post
    Im getting an Error when trying to load a previously modified CM2100 CSP5 tune to edit in 7.5. Seems to have happened with the update.Attachment 21275 Cant load any CM2100 CSP5 tunes. No matter what the OS.
    An update to fix this has been posted in post #1.
  3. #23
    email sent.
    This is what it looks like (blue dogears):
  4. #24
    It should display like this:
    Note: that you can see the red (out of EFILive's range) border on the cells if/when you highlight them.
    Something's up with the EFILive_Tune.exe in the beta-4 install - looks like I may have built it with an older version.
    Have you tried updating to the EFILive_Tune.exe attached to post #1.
    I'm planning on posting beta-5 update in the next day or two.
  5. #25
    After much "investigation" the beta-4 *.exe is the correct *.exe and not an older version like I had thought.
    To allow the EFILive min/max values to be overridden you need to check the property option:
    Edit->Properties->[Options]->"Allow calibration values to exceed recommended limits."
  6. #26
  1. April 2017, Beta Release 2
    Last Post: June 29th, 2017, 03:06 PM
  2. April 2017, Beta Release 1
    Last Post: April 18th, 2017, 02:31 PM
  3. July 2016: EFILive Beta Test Release
    By Blacky in forum EFILive Beta Software
    Last Post: September 5th, 2016, 03:18 PM
  4. EFILive July 18th Beta Release (CSP5)
    By GMPX in forum Software Updates and Installation Help
    Last Post: August 22nd, 2013, 02:18 AM
