Results 1 to 10 of 11
Thread: E38 LS7 exhaust gas temps on idle?
    Member Age08's Avatar
    Jun 2012
    Default E38 LS7 exhaust gas temps on idle?
    Does this sound right for exhaust temps on idle which are around 360-400c with the engine @ 90c?
    the motor is a LS7 with heads milled 20' and a cam with .649In/.660Ex lift, 227/243 duration and lsa 115,
    Air fuel on idle is 14.5-14.7, with timing hunting around 15-20.
    How are you measuring...?
    Jun 2012
    I am using a Egt probe installed on the number 2 cylinder exhaust port.
    Those temps are ok for warm idle.
    What do they hit at WOT...?
    Jun 2012
    When I get a chance today I data log it,
    Also I was little out on the temps it's actually 525c not 400c on idle, I calculated wrong from Fahrenheit,
    Now the probe is right on the main against the exhuast port of that makes a difference
    Are you running catalytic converters...?
    The key is this:
    - at idle you want barely enough temperature to keep the cats lit (something like 400-600*F).
    - at WOT/load you want to be below the catalyst danger threshold (about 1200* F or under).
    Jun 2012
    I am running cats,
    Jun 2012
    Here a log I did while driving steady at 100kmh, its has a short wot burst never the end,
    BTW: for E38 log GM.ETCTP instead of GM.ETC, and log GM.HO2Sxx instead of O2Sxx.
    I think you're ok... I see COTP kicking in briefly, this is normal after a WOT pull.
  1. E38 Temps?
    By IJ. in forum E37, E38 & E67 PFI ECM's
    Last Post: March 9th, 2017, 04:51 PM
  2. E38 LS7 Idle AFR drifting
    By billybrun in forum E37, E38 & E67 PFI ECM's
    Last Post: October 21st, 2014, 06:33 AM
  3. LBZ exhaust temps
    Last Post: September 23rd, 2008, 10:24 AM
  4. Fan temps on an E38 File
    By Dirk Diggler in forum E37, E38 & E67 PFI ECM's
    Last Post: February 10th, 2008, 04:48 PM
