Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 42
Thread: SAE.MAP not working properly with C7Z06
  1. #31
    Lifetime Member wesam's Avatar
    May 2010
    Today I tuned my first 2017 ZL1
    It still has the same issue with latest Oct public release
    the car has OS 12682377
    Attached a log for KOEO and first start
    EFILive Tuner
  2. #32
    Quote Originally Posted by wesam View Post
    V8 pass-thru logging and Black Box Logging should return the correct values.
    I can confirm the problem still exists when using V7 pass-thru logging. It will be fixed in the next update.
    Until it is fixed, you can use Hex Workshop (or similar hex editor) to modify the log file to correct the result as follows:
  3. #33
    Paul, thanks.
  4. #34
    I take it that is 39 decimal...?
  5. #35
    Yes, the values are decimal.
    Originally (for most older controllers), the SAE.MAP PID range is limited to 0..255kPa - since that is the range of a single byte value used to carry the MAP value.
    When MAX_MAP is not zero (on some late model forced induction engines), the range is modified by 10 times that maximum value. So for 39, the maximum MAP value is modified from 255kPa to 10*39 = 390kPa. Which gives a new range of 0..390kPa for the SAE.MAP PID.
  6. #36
    Feb 2006
    Joe watch the "decimal reference" they are not decimals on the Hex side. They are 0D and 0A or "Zero D and Zero A"
    Thanks for the help guys.
    Al
  7. #37
    Quote Originally Posted by ChipsByAl View Post
    Al
    Hey Al, how's it going
    Yes, anything that is not alphanumeric or not punctuation (e.g. 0D, 0A) is represented as a dot.
  8. #38
    May 2010
    Bump
    Still the same problem with Dec Public release
    EFILive Tuner
  9. #39
    Bump
    V7 pass-thru logging?
    V8 pass-thru logging?
    or
    V8 standalone black box logging?
    If possible can you perform a V8 pass-thru log of the PID and afer stopping the log, save a trace file using the EFILive Control Panel and send me the trace and the log files?
  10. #40
    May 2010
    EFILive Tuner
  1. SAE.MAP reading lower than expected in C7Z06
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: June 19th, 2017, 05:13 PM
  2. E67_AFRATIO_DMA is not working properly ?!!
    By wesam in forum E37, E38 & E67 PFI ECM's
    Last Post: August 31st, 2015, 03:43 PM
  3. DSP output not working properly
    By hot-dog in forum Duramax LB7
    Last Post: April 10th, 2014, 02:11 PM
  4. E39_AFRATIO_DMA is not working properly
    Last Post: June 20th, 2013, 04:51 AM
  5. Cruise not working properly after tire calibration
    By Max Power in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 30th, 2012, 12:26 PM
