Results 1 to 7 of 7
Thread: serial lc-1 logging
    Jun 2016
    Default serial lc-1 logging
    How close should my logged lambda be to what my Dyno Tune gauge is displaying? I seem to be logging .2 AFR richer than what my gauge reads. Not a huge deal, but it would be nice if they were closer.
    Also, is there some way to get my gauge to display in lambda, I'm not a fan of AFR anymore.
    Thanks!
    '98 Z28 S475
    Where are the sensors located...?
    Which gauge do you have...?
    Jun 2016
    O2 sensor is about 24" off the turbo. The gauge is the round digital Dyno Tune Air/Fuel, like this, https://www.dynotunenitrous.com/stor...?idproduct=388
    '98 Z28 S475
    Do you have the user manual pdf's for the LC-1 and the gauge...?
    Jun 2016
    I don't believe so. I've had these over 10 years I bet. You think I have the voltage offsets wrong for the gauge maybe?
    '98 Z28 S475
    Does the gauge run from on eof the LC-1's analog output's...?
    If so, then you can use the LC-Programmer software (from Innovate) to tweak analog output a little to make the gauge match.
    Jun 2016
    Yes it's on 1 of the analog outputs. So what I'm logging is the most accurate because its coming straight from the serial connection on the LC-1. And the gauge is just interpreting the values programmed into it. Bring the gauge inline and all is well. Thanks joecar, seems so simple after typing it out!
    '98 Z28 S475
  1. Help setting up serial logging into v7.5 scanner
    By Jacob lowe in forum External A/D inputs
    Last Post: February 11th, 2016, 01:34 PM
  2. LC1 serial cable logging??
    By tdmkr496 in forum Gen III V8 Specific
    Last Post: March 4th, 2014, 11:47 AM
  3. Serial logging and tuning with 2 LC-1's
    By truethinker in forum External A/D inputs
    Last Post: July 9th, 2012, 03:11 PM
  4. Need Help w/LC1 Serial Logging
    By TFZ_Z06 in forum FlashScan V2 BB Logging
    Last Post: August 4th, 2008, 03:35 PM
  5. LC1 Serial Logging
    By oztracktuning in forum General
    Last Post: November 8th, 2005, 06:45 AM
