Results 1 to 10 of 12
Thread: Traction Control
    Senior Member SV8346's Avatar
    Nov 2007
    Default Traction Control
    Does anyone know if its possible to edit or adjust the traction control levels in the E98? With it on it just continuously wipes out the throttle on take offs or hill climbs but if you have it turned off it just turns tires everywhere. Would be nice if it was adjustable as to the level of traction control?
    2016 RG Colorado 2.8TD
    I'm not sure about that, do you know if the system on the Colorado uses the brakes too or purely throttle (well, fuel) control?
    Nov 2007
    Throttle control of some sort. So would need to be a fuel cut in someway which makes me thing that somewhere along the line it would be controllable by the ECU?
    Quite possibly also has some style of brake traction control for the ESC and also when driving offroad i believe it possibly could be brake controlled?
    But what i have found is that when i take off from standing start and it wheel spins it definitely feels like it fuel cut as the throttle is non responsive for a second or 2 and also boost drops to near on nil.
    Nov 2007
    Any luck with this yet?
    I was away all of last week
    Nov 2007
    All good, i'll check back in in a week or so and see if any update on this.
    Apr 2010
    Quote Originally Posted by SV8346 View Post
    are you just turning off traction control or ESP as well?
    Nov 2007
    Have tried with both. As soon as i turn off TC it turns tyres hard off the line. Would be pretty awesome to be able to take off hard without turning tyres yet still having as much power as possible to still keep traction. At the moment as soon as it starts to turn them it just basically shuts off the throttle and leaves you with a foot full of nothingness haha. Hopefully there is a way of being able to adjust the level of throttle control within the traction control. I know it can be done with the older LS1's so i was hoping(fingers crossed) it could be done with these computers as well.
    Apr 2010
    It was never a tunable deal in the older LS1...all the traction control hysteresis are reactive...ie it needs to see the wheels spin before it removes power. How aggressive it is at removing power is adjustable but so is the throttle position!
    Reckon you are in the world of it is a hinge not a switch...no traction control device is ever going to be able to predict the amount of slip you will get at any given set of circumstances. If you are in limited traction situations...try setting up some stuff in a DSP4 selectable calibration.
    Nov 2007
    Quote Originally Posted by HOWQUICK View Post
    You're right it wasnt the LS1's it was the LS3's that we used to do it in.
    You're also right, its not actually a prediction of traction loss but more of a calculation of traction loss due to torque produced. Its a torque limit that can be altered in specific gears at specific throttle amounts at specific rev ranges. IE; if you know that in 1st gear at 80% throttle at 1400rpms it produces 440nm of torque but at 260nm it starts to wheel spin then you can limit that specific point to 255nm of torque so that you are always right on the edge of wheel spin without actually turning tyres. See below for where we use to alter the TCS in the older ls3's
  1. ABS, Traction control, Cruise control..
    By GMCAMARO in forum Gen III V8 Specific
    Last Post: January 23rd, 2016, 03:10 PM
  2. Traction control off
    By Suhail in forum E37, E38 & E67 PFI ECM's
    Last Post: March 2nd, 2010, 10:29 PM
  3. traction control off
    By jeff keyuk in forum Gen III V8 Specific
    Last Post: February 14th, 2010, 05:11 AM
  4. traction control
    By 69camaro5speed in forum E37, E38 & E67 PFI ECM's
    Last Post: September 29th, 2007, 03:11 AM
  5. 04 vz ss traction control
    By rocket in forum General (Petrol, Gas, Ethanol)
    Last Post: April 5th, 2007, 10:22 AM
