Results 1 to 9 of 9
Thread: Bastardized lb7
    Feb 2016
    Default Bastardized lb7
    Hey. I have a problem lb7. Truck came for me for tuning after a hack put a bunch of used parts on reused every seal and had stuff bent and twisted. Even had a broken wire fixed with a coder pin jammed in the main engine harness connector lol. It has S366, air dog lift pump, stage three cp3 (12mm) w/lbz frp (stage 3 floor it diesel cp3) headstuds/gaskets, built trans. Truck won't start on its own. off idle it builds proper rail pressure still doesn't run right with ppei max effort tuning for pump and turbo. And second pic is key on engine off. Injectors have 30k on them supposedly.
    Lifetime Member LB72004's Avatar
    Dec 2011
    Does this truck have an LBZ regulator in it?
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
    Feb 2016
    The stroker pump had a lbz regulator on it yes. We tried the stock one on it and no change.
    Dec 2011
    how many RPMs on cranking?
    have you looked over all of the fuel system, filter housing for leaks for air getting in? does it have a lift pump?
    can you get us the screenshot of it idling?
    Feb 2016
    Not sure on rpm rolling. Rolls over fast. Has a air dog and I've bypassed the filter housing and triple checked all the fuel lines
    Dec 2011
    run a log of the attempt to start/while cranking. up load it here for us to see
    Feb 2016
    Mar 2015
    If it's rolling over really fast trying to start it wouldnt that indicate loss of compression? Maybe not complete loss but one or so cylinders?
    Sent from my LG-H910 using Tapatalk
    Feb 2016
    So after doing injectors it starts mint has agressive diesel knock. After screwing with it desired rail pressure was double unhooked the air dog and it
  1. LB7 help please
    By RUTAN TA in forum General (Diesel)
    Last Post: March 2nd, 2014, 12:29 AM
  2. 01 LB7 PCM in 04 LB7 truck?
    By KLUG'S SS in forum Duramax LB7
    Last Post: December 26th, 2013, 01:25 AM
  3. RR for LB7
    By GL4787 in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 8th, 2009, 01:12 PM
  4. Need OS for 01 lb7 pcm
    By red12secz28 in forum Duramax LB7
    Last Post: November 21st, 2007, 09:32 AM
  5. 03 LB7 pcm into 01 LB7
    Last Post: November 19th, 2007, 09:40 AM
