Results 11 to 20 of 27
Thread: July 2017, Beta Release 5
    Perfect thanks for the fast support
    04 LB7
    2010 LMM
    2015 LML
    Updated firmware is now available.
    Thanks I will give it try in the morning
    04 LB7
    2010 LMM
    2015 LML
    Jul 2003
    Huge update
    Flashing now works thanks
    04 LB7
    2010 LMM
    2015 LML
    Jul 2003
    Jan 2010
    Having trouble with AL5 Transmission controller I previously read, licensed, and modified on a friends truck. I have Tried in V8 and V7.5 software. I update the latest Beta with the firmware 119 attachment in the first post.
    The E60 engine controller is no issue. It's only the AL5 transmission controller.
    I can not read it,
    I can flash it
    I can not full flash
    When I request calibration details It gives me another error. But when you click ok you get all the details like nothing is wrong.
Name:	V8 AL5 331 error.jpg
Name:	V7.5 AL5 error.jpg
Name:	AL5 compatibility.jpg
    Quote Originally Posted by 1FastBrick View Post
    Can you please locate the trace file that was saved when the trans read or flash was attempted? It will be located in the folder: \Documents\EFILive\V8\Trace
    Send it to me paul@efilive.com with a link to this thread so I know what it is about.
  9. #19
    Jan 2010
    Paul, I just E-mailed you what I have for now along with a link to the thread. Thanks!
    Maybe You can point me in the right direction.
  10. #20
    Jan 2010
    Well I was able to read a different 2005 AL5 today so it appears to be isolated to that specific truck. I pulled the fuse for the radio and no luck.
    I attempted to read the problem truck a few times with no luck.
    I read the other truck which is also registered and tuned on this cable with No issue.
    I then went back to Problem truck and reflashed the TCM through TIS thinking maybe something was corrupt. Then attempted another read an no dice.
    Other then making or purchasing an adapter for my bench harness, not sure what else to do with it.
    Just thought I would update you on what I found
  1. July 2017, Beta Release 4
    Last Post: July 10th, 2017, 03:42 PM
  2. April 2017, Beta Release 2
    Last Post: June 29th, 2017, 03:06 PM
  3. April 2017, Beta Release 1
    Last Post: April 18th, 2017, 02:31 PM
  4. July 2016: EFILive Beta Test Release
    By Blacky in forum EFILive Beta Software
    Last Post: September 5th, 2016, 03:18 PM
  5. EFILive July 18th Beta Release (CSP5)
    By GMPX in forum Software Updates and Installation Help
    Last Post: August 22nd, 2013, 02:18 AM
