Results 1 to 3 of 3
Thread: 2016 LML Post injection disable
    Sep 2009
    Cool 2016 LML Post injection disable
    Hi,
    I recently tried turning the enable calibrations for DPF, SCR, and Exhaust temperature control off. After I shut these features off, I noticed that the post injection is still on, but system is staying in normal mode (injection timing is not going really negative to heat up the after treatment system). I followed some of the different threads, the reference to the {B1021} calibration for injections that are on/off is no longer there in the current calibration set (at least from what I can find). Can anyone provide some insight on this? Thanks!
    Last edited by DieselAdam; July 12th, 2017 at 11:46 AM. Reason: Wording was not good.
    Dec 2015
    The LML doesn't really use post injection for temperature control. You're fine keeping it as is.
    If you want you can find those tables and tinker but... I doubt it's worth your time.
    Sep 2009
    Okay, thanks.
  1. Disable Auto Stop on 2016 Chevy Malibu 1.5L
    By jaydog in forum Petrol / Gas
    Last Post: June 3rd, 2017, 11:38 AM
  2. Post Injection
    By EverydayDiesel in forum Cummins 6.7L
    Last Post: February 5th, 2016, 05:04 PM
  3. Post Injection Problem - DPF Delete enabled, Post Inj #2 still squirting!
    By dmaxhumvee in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 22nd, 2012, 03:28 AM
  4. Post Injection
    By petestoy in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 2nd, 2011, 12:31 AM
  5. disable pilot injection on LBZ
    By justin123 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 21st, 2009, 10:16 AM
