Results 1 to 8 of 8
Thread: A50 vin
    May 2013
    Default A50 vin
    Hi I'm trying to flash my stock vin into a new A50 tcm for my 2011 LML. I read the new tcm and changed the vin in v8 under properties. When I reflash my tcm with new file and read it out again the vin goes back to all zeros. What am I missing ?
    Jan 2006
    You can change it in the V7.5 scan tool.
    04 LB7
    2010 LMM
    2015 LML
    May 2013
    I've gone into 7.5 and changed it then saved the file. But when I flash it to the tcm it doesn't take the vin. It stays all zeros.
    Jan 2006
    SCAN TOOL not the tune editing tool.
    04 LB7
    2010 LMM
    2015 LML
    Jan 2006
    You will need to connect to the TCM with the scan tool
    04 LB7
    2010 LMM
    2015 LML
    May 2013
    Thanks man that did the trick. I really appreciate it !
    Jan 2006
    Yeah I fought with that one to
    04 LB7
    2010 LMM
    2015 LML
    +1 always use the scantool to change the VIN on any PCM, ECM, TCM.
  1. changing vin on lmm to my suburban vin. is this doable?
    By Madspeed in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 24th, 2015, 02:14 AM
  2. A50 stream
    By vectorbundle in forum Allison 5 & 6 Speed
    Last Post: June 8th, 2015, 02:30 PM
  3. A50 tuning
    By Dragbear in forum Allison 5 & 6 Speed
    Last Post: November 7th, 2014, 12:18 PM
  4. what vin do i use the ecm vin or the dash vin
    By nycblazer in forum General (Petrol, Gas, Ethanol)
    Last Post: March 23rd, 2008, 03:31 AM
