Results 1 to 3 of 3
Thread: New stage five
    Sep 2015
    Default New stage five
    Just picked up the truck after a week in the shop. Need intel on learning procedure. I did a dozen runs at the strip at my builders shop for a fast learn but is there something more. I figure I will take it off optimized stock tomorrow and see what it can do.
    2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, Custom tune on v2 for daily driver, 33x12.5 nitro at on 20 inch American steal wheels, modded factory air box, Profab Intake Horn, Batmo Wheel, Turbo port and polish, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust axle dump, 10mm lbz cp3 pump, Dual Yellow Top Optimas, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Contol arms, Drilled and Slotted Rotors on all four Corners, FEd Y Bridge.
    Lifetime Member LB72004's Avatar
    Dec 2011
    Slowly ease into giving the transmission more and more power. Make sure to get up to speed going through all of the gears and back down again down shifting to 1st. Do this several times until smooth and then do it again with more throttle each time until you reach WOT.
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
    Sep 2015
    I am just using it to drive to work for now. I will wait for wide open pulls till after the new turbo and all the supporting mods go in. And my tuner is on vaca.
    2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, Rick Fletes Dsp 5 on v2, 33x12.5 nitto at on 20 inch American Racing 20x10 wheels, Stage 5 Built Transmission by Mike Cole with triple disc billet low stall converter, 4 inch Injen cold air intake, Profab Intake Horn, Batmo Wheel, Turbo port and polish, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust axle dump, lbz cp3 pump, Dual Yellow Top Optimas, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Upper Contol arms, Drilled and Slotted Rotors on all four Corners, FED Y Bridge, Shantz Custom Fab Traction Bars.
  1. Dual stage nitrous on a COS5
    By joeygc5 in forum Custom Operating Systems
    Last Post: November 27th, 2012, 05:03 AM
  2. Stage 3 timing table
    By dennisscars in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: November 14th, 2008, 05:09 PM
  3. Two Stage Nitrous Dry/Wet
    By Beer99C5 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: February 9th, 2008, 03:30 PM
  4. 2 stage rev limiter
    By hymey in forum E37, E38 & E67 PFI ECM's
    Last Post: February 6th, 2008, 12:29 AM
  5. TTi Stage 1 Question/DIY Tuning
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2005, 03:00 AM
