Results 1 to 10 of 17
Thread: Read out friends tune... all "unknown"
    Apr 2011
    Default Read out friends tune... all "unknown"
    2007 GMC 2500 P/U (classic) -- Read out the tune, tried to open, and everything on the left just says "Unknown".
    Was this modified by some other hand-held programmer? Can I flash it over with a fresh stock tune and go from there?
    What ECM type?
    It may simply be an unsupported OS or a custom OS by another tuning program that EFILive will not recognise.
    Apr 2011
    What ECM type?
    If it's not readable, would I be able to find a stock tune, and do a full flash?
    Thanks-
    Yes, that is a very early OS that GM has released updates for multiple times.
    Updated OS's are:
    12613248
    12619624
    If you find a suitable stock tune with either of those OS's then you should be fine to full flash over the top of the old OS.
    Both of those updated OS's are supported in EFILive.
    Junior Member GM-Josh's Avatar
    Jun 2016
    Agreed with GMPX, this thread has had a chunk of the community pitch towards a drop box(s), Tunefiledepot has been replaced... , I have a bunch of GM files but seems like the ones I didn't have I found here, major props to all who stepped up.
    :EDIT: Click image for larger version.
Name:	Screen Shot 2017-07-17 at 10.34.49 PM.png
    Apr 2011
    Quote Originally Posted by GM-Josh View Post
    Can you help me out with a link to the tunes? Thanks--
    Sure thing Jim, here's the DropBox link: DropBox repository for EFILive tunes. Go into the GM Truck folder, look for a compatible file. Download it, then full flash it, make sure the VIN is correct, and you should be good to start tuning.
    Apr 2011
    Thanks, great resource!
    -- Nothing in there quite matches up (at least, it seems???) I am still on the hunt...
    Jun 2016
    Thank you ScarabEpic22!
    Quote Originally Posted by Jim_PA View Post
    Hey Jim, I found one with the first OS (12613248) that Ross posted up for a 2007 Classic: 2007 Chevy Silverado Classic 4.8 LR4 4L60E
    What does the truck have in it now, is it a 4.8? If it's not, you'll either have to tweak this base file to suit the truck (VE, MAF, injectors, spark, transmission, ...) or get a factory-fresh file for it using SPS. I know for a while, some shops were selling base tunes where you pay a fee (was around $50 IIRC) and they'd use your VIN, flash a controller via SPS, read the file out and email it to you. I don't know if anyone is doing that still and I dont think I have a 1MB LS1 PCM lying around.
  1. V2 won't read E38 ECM (Shows "EXT" in V8)
    By powerfreak in forum FlashScan V2
    Last Post: March 20th, 2015, 06:19 PM
  2. Replies: 3
    Last Post: March 6th, 2011, 02:12 PM
  3. P0601 "Control Module Read Only Memory (ROM)"
    By WI Huck in forum RoadRunner Real-Time PCM Emulator
    Last Post: July 23rd, 2009, 02:51 AM
  4. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  5. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
