Page 9 of 9 FirstFirst ... 789
Results 81 to 87 of 87
Thread: The AEM 30-0334 OBDII X-Series Wideband for FlashScan V2 is finally available,
  1. #81
    Feb 2007
    Thank you
  2. #82
    Nov 2011
    Can anyone show me a log with the BEN working AND how you defined the calc pid? I'm still running issues.
  3. #83
    Chuck,
    Putting this in UserCalculatedPids.ini would define BEN pids for serial-comm and CAN-bus connected widebands:
    Code:
    [Groups]
    GLOBAL=Global Functions
    WO2SER=Wide Band O2 Sensors (Serial-Comms)
    WO2CAN=Wide Band O2 Sensors (CAN-bus)
    [WO2SER]
    WO2BEN="Base Efficiency Numerator (Serial-Comms)",factor,3
    [WO2SER.WO2BEN]
    0=|-- WO2SER.WO2BEN
    1=|return pid("WO2LAM1")*pid("EQIVRATIO")
    [WO2CAN]
    WO2BEN="Base Efficiency Numerator (CAN-bus)",factor,3
    [WO2CAN.WO2BEN]
    0=|-- WO2CAN.WO2BEN
    1=|return pid("WO2S11")/pid("EQ_RAT")
    You wold then use WO2CAN.WO2BEN as the BEN pid.
    Hey Joe,
    When you say "can bus connected widebands" do you mean the RS232 serial wideband connections?
    Chuck CoW
  4. #84
    Quote Originally Posted by Chuck CoW View Post
    Hey Joe,
    Chuck CoW
    No...
    the AEM 30-0333/0334 connects to FSV2 via the CAN bus.
  5. #85
    The AEM 03-0333/0334 do not have serial comms (please correct me Dr.Mike).
  6. #86
    No...
    Hey Joe.. SO, has EFI LIVE added a pid to help scan and log the AEM pid? That sounds like a cool feature, but not having serial is not a great idea and
    let's suppose you're tuning an LS1 or any other NON-CAN controller, how would you log it if there is no can bus and the wideband has no serial output.
    Going back to analog don't make sense.
    Chuck CoW
  7. #87
    The 0333/0334 still outputs analog 0-5V, but is more intended for E38, E67, E92 tuning.
    The 0333 is specifically for single wideband to CAN; the 0334 is for dual widebands to CAN.
    EFILive has a means to connect to one or two CAN bus connected widebands, including pids.
  1. AEM X-Series OBDII Wideband UEGO AFR Sensor Controller Gauge
    Last Post: July 24th, 2017, 07:58 AM
  2. AEM X-Series Wideband - Serial
    By Gregs in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2017, 07:20 AM
  3. AEM wideband to FlashScan V2
    By T34418L31 in forum FlashScan V2
    Last Post: May 13th, 2015, 11:22 PM
  4. aem wideband and efilve v1
    By badls1 in forum External A/D inputs
    Last Post: June 22nd, 2011, 02:56 AM
  5. FlashScan V2 OBDII Cable
    By minytrker in forum Purchase and Shipping
    Last Post: November 25th, 2008, 02:37 AM
