Page 11 of 11 FirstFirst ... 91011
Results 101 to 104 of 104
Thread: The AEM 30-0334 OBDII X-Series Wideband for FlashScan V2 is finally available,
  1. #101
    Quote Originally Posted by s4door View Post
    I have recently installed the AEM 30-0334 in my truck. I have a 2010 6.7 Cummins running as a stand-alone in a 92 F350. The ECM is a CM2200. I select the CM2200 as the ECM and then the AEM 30-0334 as the TCM to monitor both simultaneously. When I then click OK to confirm my two choices I get the following error:
    Transmission controller: AEM UEGO Bank 1 has not been selected because it is incompatible with engine controller: CMD CM2200 Cummins Diesel ECM.
    I am able to independently select the CM2200 and then the AEM 30-0334 and program the V2 with both controllers independently. I can then successfully log data form either but not both at the same time. I need to be able to monitor both at the same time. Am I doing something wrong or is EFILive not setup to do this? I also tried to link other GM Diesel ECMs with the AEM 30-0334 and would get the same error.
    The AEM wide band controller simulates a CAN module on the GM CAN bus using GM specific OBDII messages to transmit the wide band data to FlashScan/AutoCal devices.
    Cummins ECMs use a different data logging message structure which is not compatible with the message structure that the AEM has been programmed to simulate.
    Therefor it is not possible to log both Cummins and AEM simultaneously.
  2. #102
    Oct 2014
    Would I be able to connect the AEM to my V2 in pass thru mode connected to my laptop via the serial port or Analog output that the gauge also has for communication and then be able to log data simultaneously?
  3. #103
    If your AEM is compatible with the AEM UEGO serial interface that FlashScan supports, then yes you should be able to do that.
  4. #104
    Oct 2014
    Thanks I will give that a try. I have the serial cable that came with my V2
  1. AEM X-Series OBDII Wideband UEGO AFR Sensor Controller Gauge
    Last Post: July 24th, 2017, 08:58 AM
  2. AEM X-Series Wideband - Serial
    By Gregs in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2017, 08:20 AM
  3. AEM wideband to FlashScan V2
    By T34418L31 in forum FlashScan V2
    Last Post: May 14th, 2015, 12:22 AM
  4. aem wideband and efilve v1
    By badls1 in forum External A/D inputs
    Last Post: June 22nd, 2011, 03:56 AM
  5. FlashScan V2 OBDII Cable
    By minytrker in forum Purchase and Shipping
    Last Post: November 25th, 2008, 03:37 AM
