Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 104
Thread: The AEM 30-0334 OBDII X-Series Wideband for FlashScan V2 is finally available,
  1. #51
    Jun 2019
    Need to make a post
  2. #52
    Jun 2019
    You should have gotten the 30-0333 if you're running only one wideband; the 30-0334 is the second wideband if you're dunning two widebands.
    But it appears the 0334 works by itself.
  4. #54
    Post the log files you're getting.
    On your AC where/what are the logs being saved to...?
  5. #55
    Jul 2016
    IIRC, The 30-0333 does not support EFILive. Just "Brand H". The 30-0334 was designed to work with EFILive in both single and dual configurations.
  6. #56
    Jun 2019
    Here's the log file. On my autocal, the files are being saved to the scan folder as an .efi file extension.
  7. #57
    Jun 2019
    Even if I use my autocal as a pass through and log with my laptop, I get the same results. If I unhook my autocal, or turn off my car and wait for it to time out and turn off, that's the only way I get the wideband and autocal to talk again, but it's always only for a few minutes.
  8. #58
    Quote Originally Posted by dr.mike View Post
    dr.mike, thanks for the clarification.
  9. #59
    Jun 2019
    Joecar did you see anything with my log?
  10. #60
    The problem appears to be the data coming from the wide band. The data does not stop abruptly, but ramps up to an invalid/faulty value over a number of frames as shown below. That implies (to me) that the wide band has failed and the output from the wide band has drifted to its maximum value over a sequence of 4-5 frames.
  1. AEM X-Series OBDII Wideband UEGO AFR Sensor Controller Gauge
    Last Post: July 24th, 2017, 08:58 AM
  2. AEM X-Series Wideband - Serial
    By Gregs in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2017, 08:20 AM
  3. AEM wideband to FlashScan V2
    By T34418L31 in forum FlashScan V2
    Last Post: May 14th, 2015, 12:22 AM
  4. aem wideband and efilve v1
    By badls1 in forum External A/D inputs
    Last Post: June 22nd, 2011, 03:56 AM
  5. FlashScan V2 OBDII Cable
    By minytrker in forum Purchase and Shipping
    Last Post: November 25th, 2008, 03:37 AM
