Page 7 of 11 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 104
Thread: The AEM 30-0334 OBDII X-Series Wideband for FlashScan V2 is finally available,
  1. #61
    Jun 2019
    Paul, can I have you validate this with another log where the values dont jump so much? The spikes you see in the log is where I let off the throttle and I'm coasting. I have logs were im just sitting idle and the stream stops with no major fluctuation like you see here. I will post another log when I get home in about an hour and a half.
  2. #62
    Jun 2019
    Here is another log of me just idling then it does the same thing. Although I forgot to change the pid on the controller, i was going through all the pids for the wideband and testing to see if they all did the same thing or if one of them would actually log this thing.
  3. #63
    Jun 2019
    Here is another thing I wasnt thinking about last night, when the streaming stops, if I unplug my autocal and plug it back in then go back to record or display data, the streaming will start back up for a few minutes again. This is without turning off the wideband or turning off the car.
  4. #64
    Quote Originally Posted by Dman View Post
    Are you able to use pass-thru logging (from a PC or laptop) along with the V8 scan tool to log the wide band data?
    If you can do that, then as soon as the the wide band data flat lines (well within 10-20 seconds), stop the log and open the EFILive Control Panel and save a trace file and send me the trace file (paul@efilive.com).
  5. #65
    Jun 2019
    Yes Paul I can do that, I may already have a file. I will get my laptop and check, if not I'll get you one within an hour. Thanks for your help, this has been a headache for about 3 weeks now.
  6. #66
    Thanks for the log it helped but not enough, what I really need is a set of two files:
    1. The *.efi data log file where the WO2 data flat lines.
    2. The matching *.htx trace file of that same logging session.
    I need to be able to compare the trace data and the recorded data to see where the problem occurred.
  7. #67
    Jun 2019
    Ok Paul, I'm am making it right now and I will send it to you in about 5 minutes soon as freezes. Thanks for your help
  8. #68
    Jun 2019
    I sent both files, thanks again
  9. #69
    Jul 2016
    Are the keep-alive messages logged ? The ones to 0x0101
    If one is not received at least every 5 seconds, the stream will timeout. If they are sent exactly every 5 seconds, there may be a race condition.
  10. #70
    Jun 2019
    Dr.mike, you might be on to something with this keep alive thing. I was sitting in the car watching the Mv stream on my autocal and before it stops streaming, the readout on my autocal starts delaying the readout for almost a second then starts back up again every 5 to 6 seconds, it does that about 4 times or so before the stream completely stops. Is there a way to fix the keep alive part?
  1. AEM X-Series OBDII Wideband UEGO AFR Sensor Controller Gauge
    Last Post: July 24th, 2017, 08:58 AM
  2. AEM X-Series Wideband - Serial
    By Gregs in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2017, 08:20 AM
  3. AEM wideband to FlashScan V2
    By T34418L31 in forum FlashScan V2
    Last Post: May 14th, 2015, 12:22 AM
  4. aem wideband and efilve v1
    By badls1 in forum External A/D inputs
    Last Post: June 22nd, 2011, 03:56 AM
  5. FlashScan V2 OBDII Cable
    By minytrker in forum Purchase and Shipping
    Last Post: November 25th, 2008, 03:37 AM
