Hi,
I have a VZ Commodore set up in a AC Cobra and cannot get the reverse lockout to work.
Have logged the reverse lockout and it is changing status in the ECU, but the ECU output on the pin is a constant 0.5V. (Log attached)E38_0022.efi
It should ground out over 5km/h. That part of the harness is stock VZ commodore and is output is on the X2 connector, pin 11.
Tuner reckons is should be working, however, every other problem we have had has been on his end, and not a wiring issue so I have low confidence.
Any ideas - is there an alternate pin on the E38 that might be outputting the reverse lockout signal.
Thanks.
