Results 1 to 2 of 2
Thread: 2009 lmm tuning issue
    Jan 2008
    Default 2009 lmm tuning issue
    I am trying to read the program that is on it. I connect to it and it takes 45 min to compete read which I know should only take 6 min. Then it errors out to this Click image for larger version.
    HELP I think I need a PCM but would like assistance
    Dec 2005
    The ecm is locked with a patch, if its a DSP5 you will never get the file out because the file is stored on the flash chip and in other READ ONLY MEMORY areas.
    If it is a single tune and the patch is applied you won't get anything out of it either.
    Most likely you are attempting to read out a patched/locked file.
    www.mscservices.net
  1. 2009 LMM/A50 C5500 Kodiak
    By silverfox in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 17th, 2018, 03:01 PM
  2. 2009 lmm new engine gutless need help!!
    By hemi_power_3@hotmail.com in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 5th, 2016, 11:29 AM
  3. 07.5-08 tcm in a 2009-10 LMM
    By IdahoRob in forum Allison 5 & 6 Speed
    Last Post: February 4th, 2011, 10:33 AM
  4. LMM Boost Issue
    By DmaxKid in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 9th, 2009, 03:38 AM
