Results 1 to 10 of 14
Thread: RPMs coming down too fast and stalls. Car does not respond to changes?
    Jan 2007
    Default RPMs coming down too fast and stalls. Car does not respond to changes?
    Hired a tuner. He has changed the desired air flow, TC, TF many times over the course of an hour and we cant get the engine to stop stalling after a blip of the throttle.
    I have a 408 with a fast lsxrt intake and ls3 tb driven by an xlink. any known issues or thoughts? The engine just dies when I push the clutch in from 2000 rpm or dies after a punch to the throttle. I have put in a lot of honest effort and any internet advice I have found has not been fruitful. The tuner thinks the car should have responded to the values he put in by now.
    Last edited by 2002_z28_six_speed; August 18th, 2017 at 07:21 AM. Reason: removed files that are not helpful
    Aug 2009
    Post up your std un-modified file if you have it
    Jan 2007
    If it helps sure.
    Aug 2013
    Quote Originally Posted by 2002_z28_six_speed View Post
    My thoughts are that you've chosen the wrong tuner. There's more to tuning than just adding or pulling a bit of airflow.
    Jan 2007
    Quote Originally Posted by statesman View Post
    OK but that doesn't solve the problem. Anyone can make a comment like that.
    Aug 2013
    It kinda annoys me that anyone can call themselves a tuner, and charge people to do a job that they don't know how to do. You've just hired some 'tuner' to waste a gallon of your gas and an hour of your time... and then you have to come into the forum looking for help to try to fix a problem that he should have been able to fix, but didn't... clearly he hasn't got a clue what he's doing. How much did you pay this tuner?
    I'll have a look at your log file.
    Aug 2013
    I've looked at your log file and you're not logging many useful parameters, but from what you are logging...
    Your trims are having to add a lot of fuel in places (you're lean in places), and you're getting some engine knock (which is never good). The MAP readings are telling me that the whole thing is really unstable, so adding any more air to your TC or TF will probably only make the situation worse.
    I would say... go back to the stock tune file and start tuning from there. I'd also suggest logging more useful parameters (logging idle trims would be more useful than logging IAC counts).
    Jan 2007
    I did some tuning with pat G and none of the files he sent me really made anything better and then I did some tuning with lsx power tuning. did the live session and after about an hour or so it didn't really get any better.
    both people should be reconizable names but no results. very hard to get ahold of pat g. havent heard from in a month.
    need to close out project asap. can pay someone. just need it fixed.
    Aug 2013
    I've never had to clean up any tune done by Pat G... so I'm assuming he is good.
    How soon is asap?... and are you still running a stock converter on that thing?
    Jan 2007
    a couple of weeks. ideally. the truck has been in the garage for months. i live in a dense city so driving a stalling vehicle gets annoying.
    the vehicle has a manual transmission. the setup is identical to a stock work truck.
  1. 408 stroker stalls when coming to a stop
    By fat333 in forum Custom Operating Systems
    Last Post: March 7th, 2012, 07:23 PM
  2. Car dies after fast shift to third gear
    By Highlander in forum E37, E38 & E67 PFI ECM's
    Last Post: April 16th, 2011, 10:03 AM
  3. shift rpms tis rpm or engine rpms
    By 69camaro5speed in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 25th, 2008, 06:01 AM
  4. Car wants to stall with under heavy braking/fast stop!
    Last Post: April 16th, 2008, 06:45 AM
