Results 1 to 2 of 2
Thread: Vve tables
    Jul 2017
    Default Vve tables
    Ive been reading alot and trying to put it all together. I was reading about 1/2 scaling and is this necessary on a e38 with 80lb injectors, supercharged. I was on a HP tuner sight and there was a lot of talk about scaling. I thought that was what the VVE table was about, that it was a better way to tune vs scaling. so much to learn. thanks
    If you run out of injector flowrate or MAF flowrate, then you have to scale.
    You usually scale VE, MAF and IFR all together... but there are various ways to achieve the same, depending on what you are scaling.
    Scaling VE, MAF and IFR together is basically an "airmass" scale... it scales airflow and airmass (so you have to find all tables directly and indirectly referencing airmass or airflow and shift them down).
    Other ways of scaling are basically a "fuel" scale... for example, you can scale the Stoich AFR and IFR together (without effecting airmass/airflow scaling)... or you can do the same thing by playing with the fueling multiplier tables... but it depends on what limitations you are trying to get around.
  1. Replies: 18
    Last Post: March 25th, 2017, 06:36 PM
  2. E40 throttle pedal tables cruise tables
    By 04colyZQ8 in forum Gen IV V8 Specific
    Last Post: August 28th, 2014, 05:10 PM
  3. E38 trace not working in VVE tables
    By markemac in forum Petrol / Gas
    Last Post: April 20th, 2011, 01:22 AM
  4. VVE Help
    By etmotorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: February 4th, 2011, 03:52 PM
  5. EFI LIVE Tables vs HPT Tables
    By TIM Z in forum General
    Last Post: January 18th, 2011, 08:42 PM
