I have a 2015 lml, deleted the dpf and scr
now getting codes p0101 and p0234
anyone know what needs to be tweaked to make ecm happy again.
turning off the p0101 just results in a p0100
i have tried setting maf high and low to 100% (in b0121 and b0125)
have tried with egr on and off, plugged in and unplugged
scaled maf sensor readings up and down (has stock air box so scaling was a long shot at best)
i also notice the boost is limited at 250 kpa, but the ecm request goes as has as 296kpa in my logs
i am loosing my mind chasing this, any direction at all would be appreciated
I attached file if you want to take a look for me
well I figured it out, no thanks to anyone here.
