Results 1 to 10 of 10
Thread: Lml p0073
    Jan 2009
    Default Lml p0073
    I have a customer wanting me to turn off a P0073 DTC related to the AAT sensor. This is not listed in the current DTC list. What options do I have to go about getting this code removed?
    Mitch
    Mitch, unfortunately we are caught on this one (and I sympathise you are in Canada), but we can't make a 'safe' DTC listing to display, I'm happy to send you the bin of his file if you want to mess around yourself?
    Jan 2009
    Ross,
    I appreciate it, if I need it ill PM you.
    Thank you.
    Mitch
    May 2017
    That should be easy to fix. Don't forget it also has a sensor in each mirror !
    Sep 2015
    Bump.
    Client's 2015 Duramax is having the same issue and we can't figure out how to disable the code. HELP!
    Quote Originally Posted by honduh View Post
    Bump.
    EFILive does not have these parameters available in the software at all. Your options are to contact a tuner who can sell you a file with the DTCs you need disabled or dig through the hex code to find the codes yourself.
    Sep 2015
    Care to explain the “hex codes”?
    Thank you for the reply!
    Hex code, i.e. the base code the ECM runs off of. Look up hex editing and .cax files (EFILive-specific). If you're asking what hex is, you're unfortunately a few years of hard work away from being able to use it. I don't even dabble in it as it's very time-intensive to learn + expensive to buy the required hardware and software for mapping.
    Sep 2015
    Thanks again for the response! I was able to locate a 2015 file but now the cruise control kicks off shortly after setting it. Any idea what could cause that?
    Aug 2008
    All segments in the file have to match or you will loose functions on certain items.
  1. Why no DSP for LML?
    By GMPX in forum Duramax 2011+ LML / LGH
    Last Post: February 22nd, 2020, 12:18 PM
  2. LML Support
    By 30 RUM in forum Duramax 2011+ LML / LGH
    Last Post: October 25th, 2015, 11:26 AM
  3. LML codes
    By eficarnut in forum Duramax 2011+ LML / LGH
    Last Post: April 16th, 2015, 03:16 PM
  4. LML reflash
    By desltech in forum Duramax 2011+ LML / LGH
    Last Post: January 8th, 2015, 01:01 AM
