Results 1 to 5 of 5
Thread: Flashing
    Mar 2010
    Default Flashing
    I had to replace my pcm in my 01Z06. I bought a used one .I've tried doing a full flash to get my custom OS loaded. It keeps telling me that I need to license the pcm and I don't have any more license available. Is a new license required since I am replacing a pcm that is bad?
    01Z06, A4, Huron Speed Twin 67/66's on a 347
    Yes a new license is required, however if you can show the receipt for your replacement PCM EFILive will issue you a complimentary license. Send and Email to support@efilive.com with a copy of the receipt.
    Mar 2010
    Thanks Ross
    Mar 2010
    I got the license. Now the full flash keeps failing and coming back with bootloader failure. Check sum error. Any ideas?
    Mar 2009
    Not the PCM's fault. There's a fuse you need to yank and reinstall but I forget what it is. In the trucks it's something that screws with the bus. On my neighbor's truck I get 1 shot to flash it and if it fails, the easiest thing is to drive 5 minutes and reattempt. Same deal with a couple other of the Gen III trucks I've flashed. My 98 is great, the PCM talks to nothing so I can just go at it and everything works.
  1. Trouble Flashing
    By TrevorG in forum Diesel
    Last Post: April 19th, 2014, 05:12 AM
  2. need help flashing
    By 05dirty in forum Vortec V6/V8 Specific
    Last Post: June 18th, 2012, 04:50 AM
  3. Flashing different OS?
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 3rd, 2010, 10:00 AM
  4. Full flashing
    By Sparky8370 in forum FlashScan V2
    Last Post: September 23rd, 2008, 10:12 AM
  5. re-flashing
    By s10mods in forum General (Petrol, Gas, Ethanol)
    Last Post: September 18th, 2007, 10:39 PM
